01-13-2013, 12:31 AM | #1 |
Pebble Pounder Join Date: Jan 2013 Location: Seattle
| VP SCX10 transmission housing with RR bottom diff gear?
Hi there, I'm currently using the Robinson Racing one-piece bottom diff gear. I'm looking to upgrade the transmission housing to something a little tougher, and I like the VP SCX10 one. What I can't figure out is if it'll be a direct fit or not. I've read a few posts suggesting that I'll have to change my outputs, meaning stop using the one-piece. Can someone confirm that? Thanks! |
01-13-2013, 03:31 AM | #2 |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
| Re: VP SCX10 transmission housing with RR bottom diff gear?
u can use any RR gear,the one piece gear or the other one.in my comp rig i have a dig unit so i must use the single piece gear,but in my basher i use the one piece gear from RR
01-13-2013, 08:26 AM | #3 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
You have to buy a RRP one piece gear for the SCX. You can not use the wraith one piece gear with the VP SCX gear box. You could use the HR gear case and keep the wraith one piece gear.
01-13-2013, 11:56 PM | #4 |
Oh, interesting, I didn't realize there was a difference between the SCX and Wraith one-piece gears. I appreciate the heads up, I'll take a look at the HR gear case.
01-14-2013, 12:08 AM | #5 |
Pebble Pounder Join Date: Jun 2011 Location: Sonoma, Ca
| Re: VP SCX10 transmission housing with RR bottom diff gear? You are correct the best way to go is the VP casing/ crawler innovations outputs/ one piece wraith RR bottom gear
01-14-2013, 12:19 AM | #6 |
| Re: VP SCX10 transmission housing with RR bottom diff gear? I'm a little confused... the Crawler Innovations outputs are meant to bolt up to the output gear, stock or RR. The one-piece RR output gear already has the outputs... hence the one-piece part. So what exactly are you recommending? |
VP SCX10 transmission housing with RR bottom diff gear? - Similar Threads | ||||
Carbon Fiber Transmission Covers for VP XR10 Transmission Housing. | Tomy | Axles, Trannys, T-case | 4 | 01-20-2013 07:48 AM |
Ground Clearance to bottom Of X Factors Diff Case | ap714 | XTM Crawler | 4 | 03-01-2006 08:09 PM |
