01-13-2013, 08:31 AM | #1 |
Pebble Pounder Join Date: Aug 2011 Location: Norway
| Vp transmission housing problem.
Hi everybody. I just mounted the Vanquish transmission housing without the dig unit in my Wraith. But then I got a problem with the Mip driveshaft to the rear axle being to short. I got all Robinson racing gearing in the transmission. Has anybody the same setup, and how did they solwe this problem?????? Last edited by Wilson; 01-13-2013 at 08:35 AM. |
01-13-2013, 08:38 AM | #2 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
| Re: Vp transmission housing problem.
MIP makes a longer end that attaches to the trans out put. Might need two of them one for the trans end and one for the pinion end on the axle.
01-13-2013, 10:45 PM | #3 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
If you go on the MIP site and search around they have a section that gives dimensions on individual shaft pieces, and you can order them individually as well.
01-13-2013, 11:54 PM | #4 |
Pebble Pounder Join Date: Jan 2013 Location: Seattle
Wait, so the MIP shafts for the Wraith from RPP are too short? My one-piece RR lower gear is the same length as the stock outputs, so the MIPs won't work?
01-14-2013, 12:28 AM | #5 |
| Re: Vp transmission housing problem. They are if you use a VP SCX trans case and use SCX outputs. But if you use the outputs from CI they should be good.
01-14-2013, 11:54 AM | #6 | |
| Re: Vp transmission housing problem. Quote:
The problem lies in the VP housing, does not have the dig option extension. so its about 3/4" shorter than the wraith trans. | |
01-14-2013, 12:18 PM | #7 |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
| Re: Vp transmission housing problem. What he said. You could get the VP Hurtz DIG. Your standard length shafts would work with that and the VP housing. With either option, you'd have to get the AX10/SCX10 RR Diff gear to fit in the smaller housing.
01-14-2013, 01:35 PM | #8 |
I an going to try using parts from Traxxas Revo mip shaft to make the Wraith mip shaft longer. I hope that will work with the vanquish trans housing.
01-14-2013, 01:40 PM | #9 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
Clearly VP needs to make a Wraith/Ridgecrest Tranny case. I don't want to have to go through this, seems like I am not alone. Someday....... |
01-14-2013, 01:50 PM | #10 |
I wanna be Dave Join Date: Dec 2008 Location: ?
| Re: Vp transmission housing problem. |
01-14-2013, 02:18 PM | #11 |
01-14-2013, 04:48 PM | #12 |
Pebble Pounder Join Date: Nov 2009 Location: New Bern
Hot racing makes a full aluminum wraith transmission housing. I have one after stripping several mounting holes in the bottom of the plastic case set. I would have bought the VP case and dig but at the time VP wasn't using the thru hole drive shaft method and I hate the old set screw style. I emailed them awhile back about updating the outputs but never heard back if they changed them.
01-14-2013, 08:35 PM | #13 |
Vp transmission housing problem. - Similar Threads | ||||
Carbon Fiber Transmission Covers for VP XR10 Transmission Housing. | Tomy | Axles, Trannys, T-case | 4 | 01-20-2013 07:48 AM |
Ax10 Aluminum Axle and transmission housing | markdawson | Axial AX-10 Scorpion | 1 | 08-26-2008 06:36 AM |
