01-15-2013, 02:00 PM | #1 |
Quarry Creeper Join Date: Oct 2011 Location: Land of earthquakes
| Wraith version 2.0, what would you like?
Personally i would love more suspension travel but with a lower center of gravity and that the chassis would come strengthened in know stressed areas (i've changed #AX80074 4 times now), that the axles came from the factory assembled with fine thread bolts and good lockers (HR are cheap and work great) plus the Universal axles as standard, that it has more clearance on the front between the servo and frame, and a 2 speed bulletproof transmission as standard. I would happěly spent $350 for a kit version and maybe $450-500 for a RTR, if it comes with a proper brushless motor from Tekin or Castle |
01-15-2013, 02:09 PM | #2 |
| Re: Wraith version 2.0, what would you like?
I'd love it as a roller with universals, aluminum links, metal locker, and body options. Then drop in whatever electronics you want.
01-15-2013, 04:06 PM | #3 |
Rock Crawler Join Date: Aug 2012 Location: 909 area
beadlocks and front mount battery location
01-15-2013, 05:36 PM | #4 |
Rock Stacker Join Date: Dec 2012 Location: Denver
Body mounted servo and an option to do a fastback
01-16-2013, 06:23 AM | #5 |
Rock Crawler Join Date: Jan 2006 Location: Bellaire, MI
I personally don't see anything wrong with the kit version, other then I wish it included the LED light set and aluminum steering links. It has the better tires, universals, and aluminum lower links in the box. The led kit and aluminum steering links are cheap add on's though.
01-16-2013, 09:00 AM | #6 |
Yeah, front mount battery, bead locks, and fast back.
01-16-2013, 10:46 AM | #7 |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
| Re: Wraith version 2.0, what would you like? |
01-16-2013, 10:46 AM | #8 |
Let me add hinged hood to the mix....
01-16-2013, 03:23 PM | #9 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
I think it would be interesting to see a "Heavy duty kit" that comes with hardened steel diff gears, better lockers, metal transmission gears and M.I.P. driveshafts.
01-16-2013, 05:36 PM | #10 |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
Isn't upgrading and adding all the goodies and modding half the fun? I wanna CHOOSE my uni's and my driveshafts and my wheels, etc!
01-16-2013, 05:47 PM | #11 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
metal gears!
01-16-2013, 05:57 PM | #12 |
| Re: Wraith version 2.0, what would you like? Agreed, but it would be nice that it comes stock with the battery mounted in the right place, and with fine thread screw so it doesn't fell apart after the first 10 minutes of use, etc.
01-17-2013, 05:52 AM | #13 | |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| Re: Wraith version 2.0, what would you like? Quote:
Has about 30 mins on it with not a single issue. Plus while fine thread is more surface area, those threads are far easier to strip out. | |
01-17-2013, 09:27 AM | #14 |
Rock Stacker Join Date: Oct 2012 Location: Connecticut
Shocks that don't leak.
01-17-2013, 09:58 AM | #15 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
id like to see a new wraith with the Axial brushless system in it.. hd steel gears,hd steel lockers,updated beadlocks,front mounted battery tray...use's the exo rear lightbar and radiator. maybe call it the Wraith Pro kit or Wraith Hd kit..? cage mod,hood mod are easy enough to do.. |
01-17-2013, 10:37 AM | #16 |
RCC Addict Join Date: Nov 2005 Location: Utah
New chassis please, same "scale", but smaller, and more koh/ultra 4 like.
01-17-2013, 01:51 PM | #17 |
Newbie Join Date: Nov 2012 Location: Billings
Metal steering linkage and cnc sevro horn. Mainly the servo horn, ours stripped out the second battery through while crawling.
01-17-2013, 05:12 PM | #18 | |
01-17-2013, 05:25 PM | #19 | |
Newbie Join Date: Feb 2008 Location: CORAM N.Y.
01-17-2013, 07:17 PM | #20 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
I say continue to offer it with no options or upgrades to keep the price down. Im the type who likes to choose their own upgrades. I just looked at my wraith and about 75% of it is aftermarket parts and the rest of the stock stuff has numbered days |
Wraith version 2.0, what would you like? - Similar Threads | ||||
New Wraith Body -SCORE Buggy Body Version 2 | dystance | Axial Wraith | 2 | 02-23-2012 08:11 AM |
