01-23-2013, 05:44 PM | #1 |
Rock Crawler Join Date: May 2011 Location: Cali/Korea
| Wraith VP Hurtz Digs Pics and help.
Hey guys, I'm looking for some pics of your VP or just dig units with standard sized servos. I have been using minis but killing them, if you have a few pics of your setup that would be awesome. Thanks a bunch! LIK |
01-23-2013, 06:13 PM | #2 |
Pebble Pounder Join Date: Nov 2009 Location: New Bern
| Re: Wraith VP Hurtz Digs Pics and help.
I don't have that particular setup but have used a standard and mini servo for the axial wraith dig and rc4wd AX-2 2 speed. Do you have adjustable endpoints on your radio? If the endpoints aren't right the servo will sit there and buzz trying to get to the endpoint and get hot. I have seen some people use a servo saver on the 2 speed trans to get away without having endpoint adjustment. I don't think that would work good for the dig though. |
01-23-2013, 06:29 PM | #3 | |
| Re: Wraith VP Hurtz Digs Pics and help. Quote:
Thanks for the response, I have a DX3R currently and the EA is sitting at 150 haha, it wasnt buzzing at all though, but it makes sense that may be an issue, Do you use a standard with the wraith? Does it fit ok? LIK | |
01-23-2013, 06:42 PM | #4 |
A Hitec HS-225MG works fine as along as the center trim and end point adjustments are set correctly. If you want to go full sized, I have used the HS-5645MG and HS-7954SH. You can still smoke a full sized servo if the EPA is set wrong. |
Wraith VP Hurtz Digs Pics and help. - Similar Threads | ||||
Wraith interior pics? | norco kid | Axial Wraith | 26 | 11-24-2015 01:57 PM |
Wraith & Vanquish Hurtz Dig unit - what do I need? | 2-shot | Newbie General | 1 | 10-05-2015 10:53 AM |
Pics And How to for Axial Wraith!!!! | Mr.Tek | Axial Wraith | 0 | 11-30-2011 02:44 AM |
Hooking up front digs... FINISHED WITH PICS!!! | TwistedXT | General Crawlers | 19 | 03-31-2006 09:01 AM |
