Thread: mounting battery up front
Old 01-25-2013, 06:38 AM   #1
Default mounting battery up front
This has probably been covered a hundred times, could someone point me in the right direction....best way to mount the battery up front?
bigsimmo77 is offline   Reply With Quote
Old 01-25-2013, 06:42 AM   #2
Default Re: mounting battery up front
this provides protection for electrics and a scale looking fenderwell.
just installed on mine.
Wraith Electronics box
ROLANDROCKSHOP is offline   Reply With Quote
Old 01-25-2013, 06:48 AM   #3
Perfect! thanks mate....here is me trying to put it front to rear! do i need to put any weight in the back if i have the lipo and speedy up front? i use it only for crawling.
Old 01-25-2013, 06:49 AM   #4
nope..all the weight upfront will help alot.
Old 01-25-2013, 07:25 AM   #5
thanks heaps
Old 01-25-2013, 07:37 AM   #6
One of the contest entrants did an article on this. It's in the thread linked below:
Let the voting begin!!!!
TheScaleAddict is offline   Reply With Quote
Old 01-25-2013, 09:25 AM   #7
Check ckrc they sell a battery forward mounting plate that will hold a batteryand all electronics. I use one and it works perfectly!
CRAWLERJOE is offline   Reply With Quote
Old 01-25-2013, 09:52 AM   #8
Or... You could do what I did, and hack up your stock roof and use it as your forward electronics tray. It's cheap! LOL
Old 06-29-2013, 12:18 AM   #9
Thats really neat Josh. Maybe I should put moving the battery on my list of thing to do when my wraith gets here tomorrow.
midnight_f150 is offline   Reply With Quote
Old 06-29-2013, 12:51 AM   #10
Had some extra sheet metal lying around so I figured I would copy the Dinky Tray and make a housing for the Battery and RX
Its tucks in really well with a bit of room to spare.
There is enough room for the ESC and Battery, Just not sure if I can squeeze all 3 in there.
The RX is Waterproof so it doesn't need a case which is good, maybe I will just mount the esc in the stock position and then keep the rest up front.
Also working on a flip up hood for easy access..
Few Pics....just need to paint them up.
djmaincheese is offline   Reply With Quote
Old 06-29-2013, 08:02 AM   #11
I just used a flat plate on mine and tucked everything in...even a 4s lipo
Johnnysplits is offline   Reply With Quote
Old 06-29-2013, 03:32 PM   #12
zip tie the stock battery tray up front. theres pics of that floating around somewhere
evan03 is offline   Reply With Quote
Old 06-29-2013, 03:46 PM   #13
Hi,
very good idea .
jclc is offline   Reply With Quote
Old 06-30-2013, 09:47 AM   #14
mounting battery up front - Similar Threads
Front mounting plate pedlhed Axial Wraith 3 02-12-2012 12:00 PM
Front wing mounting speedcrawler Non Crawler RC's 0 08-18-2009 08:25 PM
What Battery For Use With Front Servo/Battery Plate? Shanty Axial AX-10 Scorpion 23 08-13-2009 03:05 PM
Front servo mounting? NWDave Traxxas Crawlers 9 01-30-2009 01:50 PM
Mounting batt up front? 4x4King12 Newbie General 2 07-23-2007 07:00 PM
