01-28-2013, 02:37 AM | #1 |
| SLW Hub Not Fitting Wraith Axle?
So I have 2 sets of VP Wheels (SSZ-11 and KMC's) both 2.2 and both running SLW hubs. I want the track width to be as close to original as possible so I went with 350 hubs on both sets of wheels. It seems that the axle stubs are too long and hit the back of the wheel hub so I can't mount properly. Should I try using spacers from DLux or go with the next VP wheel hub size the 475? I believe the 475 hubs give about half an inch on both sides over stock? If I went with spacers which width should i get? |
01-28-2013, 03:11 AM | #2 |
Quarry Creeper Join Date: Dec 2010 Location: Alberta
| Re: SLW Hub Not Fitting Wraith Axle?
You have to cut your CVD stub down so it doesn't hit the inside of the wheel.
01-28-2013, 09:13 AM | #3 |
Well I can either order 475's with no modding and run the 350 in the back. Or run 350's f/r with cut stubs. Last weekend I had a little bash run between courses at our comp site with a new wheel/tire setup for speed bashing and the only SLW hubs I had were 850 front and 725 rear from my XR build. I liked the awesome wheels but the stance was just not where I wanted for a scale/KOH style rig. Just way too wide for my tastes. On my Lucifer 2.2 steel KOH tuber that I just dropped Wraith axles on I will definitely need 475 hubs. Probably should just order 600 front and 475 rear that way I have enough hubs to play around with all my rigs! Ahhh VP...every time my PP fills up to a soft cushion it drains away with a single click! |
01-28-2013, 11:56 AM | #4 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
Cut the threads down a little bit with a dremel.
SLW Hub Not Fitting Wraith Axle? - Similar Threads | ||||
Fitting VP DH Ring on SLW | Colgout | Tires and Wheels | 4 | 05-04-2012 07:37 AM |
slw hub xr10 | yfz350 | Axial XR10 | 3 | 11-15-2010 05:26 PM |
slw hub??? | easleycrawler | EnRoute Berg | 9 | 10-23-2010 10:11 AM |
