01-31-2013, 11:49 AM | #1 |
Newbie Join Date: Aug 2012 Location: Seattle
| Wraith receiver/ esc/ bec issues? Please help
I am rather new to RC crawling, having used only an Exceed maxstone 1/10, and recently finally buying a wraith. Since I purchased it, it has had problem after problem. (most probably due to my excessive noob ness) mostly little things. Lately I've had one that I cant seem to fix, I was hoping you gurus of RCs could help me out with. Turning on the wraith it runs fine, forward/reverse, drag brake works, but then about 5 or 10 minutes it locks up, and is very unresponsive. The servo will tweak back and forth, the throttle won't respond, and I am left walking, cursing the whole way, back to the workbench. It DID work fine out of the box (it's theRTR) Until I tried to change some things. I adjusted the suspension (which seems like it should in no way affect electronics) I put on all aluminum links, and I relocated the battery foreward under the hood, and the esc to the back for better weight. I wonder if I may need an external BEC? I am running the stock electronics with a 5000mAh NIMH battery. Does anybody have any suggestions, orang clue what is wrong? Thank you in advance |
01-31-2013, 11:59 AM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: lexington nc
| Re: Wraith receiver/ esc/ bec issues? Please help
have u checked the low voltage dection. what batt plugs are u useing. are all bats charged an new batts in the controler. make sure there is no lose connections or frayed wires also. stock should b fine without a bec .is the radio the 2.4 setup or am. hope this helps some i tossed my stock radio in the trash when i started to have problems with it an went to my traxxas 2.4 setup no problems since
01-31-2013, 12:24 PM | #3 |
Fresh batteries in the transmitter, freshly charged 5000 mah nimh battery. I haven't checked the battery cutoff diction, no. I'm not really clear on what that is to be honest.
01-31-2013, 12:25 PM | #4 |
I meant the low volage diction, sorry I was reading another thread and got words mixed up in my head |
01-31-2013, 12:44 PM | #5 |
low voltage is for lipo batts if u r usein nimh that may b the problem do u have the castle link if so hook up to your computer an turn it off but rember if u go to lipo batts it will need to b turned back on as it keeps the lipos at a safe voltage
01-31-2013, 12:53 PM | #6 |
So you're saying lipo cutoff may be on?
01-31-2013, 02:03 PM | #7 |
yup it may be i had a prob with my stock esc cuttin out so i tossed it in the trash can thinkin it was not good an went with a vxl3s i had laying around. then my freind came over with the same prob in his scx10 he brought his castle link an boy did i feel stupid
Wraith receiver/ esc/ bec issues? Please help - Similar Threads | ||||
Wraith ESC and Receiver Box in the rear cargo area | Baja Bandido | Axial Wraith | 2 | 01-23-2013 01:04 PM |
CC BEC / ESC issues?? | RCFUN | Electronics | 17 | 03-29-2012 02:59 AM |
MRC radio and receiver with sidewinder esc/cc bec/hitec 125$servo/ 2s lipo?? | phase10 | Electronics | 5 | 03-13-2009 12:57 PM |
Receiver BEC (vs ESC BEC) | sim | Electronics | 7 | 10-13-2005 07:54 PM |
