02-10-2013, 10:25 PM | #1 |
Quarry Creeper Join Date: Dec 2011 Location: Willows
| aluminum housin
what is the best aluminum axle housing on the market for the wraith and why. thank you for looking
02-10-2013, 10:32 PM | #2 |
Newbie Join Date: Sep 2012 Location: S.W Missouri
| Re: aluminum housin
Vanquish Quality Materials Quality Machine Work
02-10-2013, 10:33 PM | #3 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
| Re: aluminum housin
Vanquish, fit and finish. really great quality. Or you could look into some of the vendors on here that make complete custom axles. |
02-10-2013, 10:34 PM | #4 |
RCC Addict Join Date: Jun 2005 Location: Prosser
| Re: aluminum housin
Vanquish because of the ability to use other aftermarket accessories designed for "stock" and of course their quality is second to none.
02-10-2013, 10:59 PM | #5 |
| Re: aluminum housin
I heard the vanquish housings are sloppy on the ends where the c hubs connect
02-10-2013, 11:29 PM | #6 |
| Re: aluminum housin
Another one for VP. They are top of the line in quality.
02-10-2013, 11:42 PM | #7 |
| Re: aluminum housin
Ok so the odds are good for me getting VP housings
02-11-2013, 03:41 AM | #8 |
Rock Stacker Join Date: May 2012 Location: Kelso
| Re: aluminum housin
I just run beef tubes in my axles and have never had one fail yet but if your heart is set on aluminum vanquish makes great parts
02-11-2013, 04:30 AM | #9 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
| Re: aluminum housin |
02-11-2013, 07:21 AM | #10 |
| Re: aluminum housin Beef tubes don't add strength to the ring gear area which in my opinion is the biggest benefit to aluminum housings. The bearing caps can flex away in the stock housings and cause nasty gear issues.
02-11-2013, 07:43 AM | #11 |
| Re: aluminum housin
I'm running a velineon 3s for now until I can afford better and I jump it and drive it to find every weak link lol
02-11-2013, 08:14 AM | #12 |
Rock Stacker Join Date: Dec 2012 Location: burlington
I plan on swapping to Vanquish Housing I looked at a couple different ones at LHS and by far I think they are the best quality. Sent from my DROID RAZR using Tapatalk 2 |
02-11-2013, 08:40 AM | #13 |
| Re: aluminum housin
i am definitely going vp
02-11-2013, 09:25 AM | #14 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
| Re: aluminum housin
Rc4wd are nice also. That's what I'm running front and rear
02-11-2013, 09:44 AM | #15 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
| Re: aluminum housin
Ive got VP everything-housings/chubs/knuckles/axles/etc and the fit of the chub onto the housing isnt loose, its sloppy. Im not impressed. The alu housings also dont slide over rocks as easily. Im a fan of VP products but not the housing/chub fit, which is a MAJOR problem imo
02-11-2013, 11:30 AM | #16 |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
| Re: aluminum housin
I run the VP housings, and I really like them. Though I have heard comments from DittoHead and others regarding sloppy cHubs, I can state that the cHub's on mine are plenty tight. I have no doubt that they have sloppy mounts, since they are reputable members of this community, and wouldn't say it were so if it weren't. That being out of the way, VP is not the only option. Integy sells complete axles. I can't speak to the quality, but they exist none the less. RC4WD also makes housings. They are well known for quality as well as for great customer service. They're axles cost less too, when you consider they come with bearing caps, cHubs, and lockouts. They also have an option for a centered axle. I wrote quite a bit more on this on my blog.
02-11-2013, 11:39 AM | #17 | |
| Re: aluminum housin Quote:
02-11-2013, 11:51 AM | #18 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: aluminum housin
With the RC4WD can you use VP knuckles and c-hubs? I like the looks of them for sure but have VP hubs and knuckles that I like because they are red anodized. |
02-11-2013, 11:58 AM | #19 |
02-11-2013, 12:00 PM | #20 |
| Re: aluminum housin Nope, RC4WD made the axle tube ends all weird. You can only use their stuff I bought them right when they came out but never even installed them because of it. Ended up giving them to a friend of mine.
aluminum housin - Similar Threads | ||||
stripping aluminum parts to the natural aluminum color | m1009cucv | Paint and Body | 19 | 05-11-2012 06:39 PM |
