02-12-2013, 05:24 AM | #1 |
Rock Stacker Join Date: Jan 2013 Location: Kentucky
| Level 3 chassis mounted servo
I got my level 3 chassis mounted servo in yesterday and out of then box I was disappointed. They sent me a little baggy of stuff with no directions or diagram of how to put together or install. I check their website and still no directions just some pictures of the parts laid out and pictures on the kit installed. So I set there and finally got an idea of how it could go together and started working on it. Finally got it installed. Was playing around with it just setting on the counter and noticed that it had gotten stiff and didn't want to flex. Then I remembered reading where someone said that a top link must be removed. So I did this and it made it a little better but itmjust didn't seem to have the same flex as before. Does anybody else have any experience with these kits. How do you feel about them? |
02-12-2013, 10:19 AM | #2 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: Level 3 chassis mounted servo
Level 3 stuff is basically garbage. I have their droop kits and the hardware they provide is very low grade. The aluminum parts look cool but I had to modify mine to look better..lol. I guess you get what you pay for!! Their stuff is cheap. VP is much, much better!! The VP CMS and panhard kits are the best available!! PERIOD! |
02-12-2013, 10:28 AM | #3 |
Never tried the Level 3 kit. Always though it didn't look to good. I have the VP CMS and panhard kit installed on my Wraith now and love it. No binding, cycles properly and looks good. Agreed with ZippoMan. VP products are the best.
02-13-2013, 05:44 AM | #4 |
I guess I will run it for a little bit and see if it holds up. It looks like these parts were cut out with a pocket knife. I won't recommend there stuff to anyone.
02-22-2013, 07:40 PM | #5 |
I been running this for a couple weeks and it limits the travel to much. Soon as I get a chance I'm gonna pull it off. I guess I'm stupid but I still don't know what the reason in for a chassis mounted servo unless it's just an option to spend money on. What is the real logic behind it?
02-22-2013, 07:44 PM | #6 |
Yes looks only!! That is why I bought mine! I wanted to get the servo off the axle. The Rubi-Wraith looks better that way in my opinion. With VP stuff I have no travel limitation...it is same as stock for articulation. |
02-22-2013, 08:09 PM | #7 |
I guess I got a pile of scrap metal.
03-16-2013, 02:07 PM | #8 |
Newbie Join Date: Sep 2007 Location: Reno
I've talked to a few people that have the Level 3 kit and it seems about 50/50 on if the kit worked out well or not. It leads me to believe that some issues are set up based, some issues are just based on "you get what you pay for". I just ordered the same kit as well based on price alone. I hate the axle mounted servo location, I've had nothing but problems with it. I'm doing a lil bit of servo work and I'm waiting to get the chassis mount in to run it again. If I can get it to run well I'll post up anything I've found to help the set up. Nearly 100% of people love the VP set up but for the money and the fact that I'm pretty ingenious in times of need I'll give the cheapo stuff a try. On the other hand you have to remember, if you're already going to spend at least 25 bux on a cheapo set but you don't want to deal with the issues then technically a VP set up is only going to cost you 25 bux out of the 50 (or what ever the cost is) due to the fact that you're already committed to spending at least half of that more expensive cost already. Just my take on it. |
03-16-2013, 02:24 PM | #9 |
Newbie Join Date: Oct 2010 Location: Griswold
Yeah Nathan from level 3 doesn't have any Customer service either.. I bought some of level 3 stuff and found out they was not compatible with my other vp stuff so i didn't use at all. Go figure Sent from my DROID RAZR using Tapatalk 2 |
05-13-2013, 03:22 PM | #10 |
Pebble Pounder Join Date: Sep 2011 Location: Bend
I went the cheap route, just got my Level 3 CMS w Panhard... looking for instructions, but I should get it installed tonight and will post back my findings as well. I love VP gear, but on this wraith I have the Level 3 steering link so figured I'd stick with the blocky look. |
05-14-2013, 01:50 PM | #11 | |
| Re: Level 3 chassis mounted servo Quote:
Vanquish Products is the only way to fly. | |
05-14-2013, 09:33 PM | #12 |
I almost had it set up. It took a lot of thought and trial of different parts. In the end the frustration of the entire thing got the best of me, we'll just say it didn't end well. The Wraith won't be running for a long time.
05-15-2013, 04:07 AM | #13 |
Quarry Creeper Join Date: Oct 2012 Location: meriden
EVERYTHING level3 makes is GARBAGE!! its a miracle they are still in business...and their products even look like crap!....VP is only way to go IMHO
Level 3 chassis mounted servo - Similar Threads | ||||
Chassis mounted servo | lurchy | Axial Wraith | 18 | 01-03-2015 05:39 AM |
CR-01 Chassis Mounted Servo | Landcruiser 110 | Tamiya CR-01 | 8 | 07-30-2012 02:26 PM |
chassis mounted servo??? | savagebeast | Axial Wraith | 4 | 05-04-2012 11:12 PM |
chassis mounted servo | twilight | Axial SCX-10 | 3 | 07-17-2009 10:21 PM |
chassis mounted servo help? | luis | General Crawlers | 4 | 08-24-2008 01:47 PM |
