02-17-2013, 12:48 AM | #1 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
| Took the plunge finally ~ Axial DIG component set:
First DIG unit ive owned yet but was it supposed to be this tidious??? i found some of it to be a touch finicky and other things that just didnt line up properly? Apparently i misplaced a bushing that came with the Wraith so i had to comprimise for this part. The holes in the RRP gear didnt quite line up making the tiny allenhead screws a PITA to bolt the Axial steel outdrive. Finished it up using a micro HiTec metal gear servo, but yet to still power this thing up and make sure it works. **used some real sticky grease on all parts while i had the transmission apart** |
02-17-2013, 07:45 PM | #2 |
| Re: Took the plunge finally ~ Axial DIG component set:
quick question..... i have an old TF-2 Tx: _________________ How do i properly adjust the DIG? or do i need a different Transmitter altogether?? or...if its possible, id like to use the TF-2 for now until i can afford a spectrum radio. thx in advance. |
02-17-2013, 08:32 PM | #3 |
Newbie Join Date: Apr 2011 Location: lancaster
You will need a new TX/RX, something that has end point adjustments. You will also need to have a AUX channel, or if you will channel 3. The dig can be adjusted once you get the new TX/RX
02-17-2013, 11:31 PM | #4 |
You need a radio that has a three position channel available for the dig servo so you can set the dig in 4x4, 4x2 and dig modes. You also need center trim and EPA so that you can correctly adjust the travel of the servo.
02-18-2013, 11:21 AM | #5 |
daaayuuum.... thats what i was afraid of! manually moving the fork back & forth, i kinda figured it but thought id ask....ill have to wait to run into the side of a bank wall ~ hopefully money will fall from the skies? lol thanks for the replies! |
02-18-2013, 04:52 PM | #6 | |
| Re: Took the plunge finally ~ Axial DIG component set: Quote:
Products - OverkillRC | |
Took the plunge finally ~ Axial DIG component set: - Similar Threads | ||||
Axial Dig Component Set | BENDER | Axial Wraith | 16 | 03-28-2012 04:49 PM |
Finally took the plunge...SCX10 Honcho Kit | kurtz49 | Axial SCX-10 | 6 | 05-18-2010 12:41 AM |
