02-17-2013, 10:10 AM | #1 |
Newbie Join Date: Feb 2013 Location: Grass Valley
| 2 weeks old, 6 break downs
New Wraith owner, multiple problems, mostly screws falling out. Looking for advice on the last/current one. This one started with the set screw for the pinion gear on the motor falling out on it's own. This caused he pinion to chew up the spur gear. We obtained a new pinion and spur and installed, with a little lock tite for the set screw. Ran well for an hour or two but started getting noisy and we found the spur gear was getting chewed up again even though the pinion was still in place. My assumption is that I installed it wrong somehow. How tight should the lock nut for the slipper spring be? I left it a bit open so that the spring was not fully closed but in that configuration the spur seems to wobble a bit when turning. I'm ordering another spur gear and looking for help installing it. Thanks. |
02-17-2013, 10:17 AM | #2 |
Quarry Creeper Join Date: Dec 2011 Location: The land of snow
| Re: 2 weeks old, 6 break downs
the only time ive had a pinion screw fall out was when i forgot to tighten it hahaha... you eating spurs sounds like you have your gear mesh wrong... Too tight or too loose, either way it'll chew it up |
02-17-2013, 10:20 AM | #3 |
Quarry Creeper Join Date: Jan 2009 Location: B-E-A-utiful Vancouver Island
I use a piece of the plastic that the gear comes in to set the mesh.... Cut a piece of the plastic, set it between the pinion and spur gear. Than tighten and spin spur to remove plastic. That has always worked for me. As for the slipper nut. Tighten all the way than back it off a quarter to half turn... That's where I like it but it is also a personal pref. some like tighter and others looser. I think it depends on your driving style. That's just MO and how I set mine so if anyone else would like to chime in
02-17-2013, 10:22 AM | #4 | |
| Re: 2 weeks old, 6 break downs Quote:
The spur gear does not need to be supper tight. It'll crack if you go too tight. Try loosening the screws a tad, then tighten just till you feel the resistance of them bottoming out. If it wobbles, try to adjust the wobble out with the 3 screws at different amounts... also make sure everything is seated correctly. Last, make sure your pinion is lined up good. If the set screw sticks out past the teeth, make sure it is not coming in contact with the spur. Also, there should be just a bit of play between the 2 gears... with 32 pitch gears, many people put a piece of paper between the mesh then tighten it down and you should be able to slowly pull the paper out without it tearing. | |
02-17-2013, 11:05 AM | #5 |
Pebble Pounder Join Date: Jan 2009 Location: Vermont
I've always used a piece of paper.If it rolls through tighT without binding it up, should be good.
02-17-2013, 11:08 AM | #6 |
Paper for me also until I learned to do it by feel.
02-17-2013, 11:12 AM | #7 |
Rock Crawler Join Date: Aug 2010 Location: Esko
With any axial rtr, always go over it and check everything to make sure it's tight. I've had a lot of them and there is always loose screws. Check everything. NOTErized! |
02-17-2013, 11:30 AM | #8 |
Rock Stacker Join Date: Jan 2013 Location: Middletown
Agreed Me and My dad both bought axial RTR's and the first day out dad's ridgecrest lost a front driveshaft because the set screw was loose and fell out we went through and had to tighten probably 15 screws on it. Also agreed if you are chewing up gears I would say you set your backlash incorrectly. I did that on my stampede burnt a motor up and did a little chewing of my gear as well just not enough to condem it . The owner of my LHS taught me how to set it by feel also mentioned the paper or plastic trick. Just like a true 1.1 ring and pinion you need a little play but not enough to where it can slip out of place.
02-17-2013, 09:04 PM | #9 |
Thanks everyone, just what I needed! |
2 weeks old, 6 break downs - Similar Threads | ||||
is neutral break the same as drag break? | rod-211 | Newbie General | 3 | 02-25-2011 08:33 PM |
Where to get tie downs/ropes for scaler | Huntweiss | General Crawlers | 2 | 01-01-2011 11:33 PM |
May 31-Day of up's and downs | tqcookie | North Dakota | 6 | 06-10-2009 12:17 PM |
60/40 Ups and Downs | ADDICT | Newbie General | 7 | 05-20-2008 09:01 PM |
