02-18-2013, 05:43 AM | #1 |
RCC Addict Join Date: Mar 2011 Location: easton
| c0bra's wraith
like the title says, ive got a wraith...... again. in fact this is number 4 however the first 3 were gone within a month! hopefully this one will last longer, to be sure its already rtr. this wraith i picked up used from the lhs for a great price, 2 weeks prior it was $20 more but had a $140 servo! unfortunately when i got it there was no servo, so i put a jr one in. unlike my previous wraiths, this one started as a kit and the previous owner put in a sidewinder esc, 20t motor (not sure what kind but it says epic on the end), full led kit, and they already painted the body and interior! i have already taken it apart and fixed a few things. first off i put a zip tie between the battery wires coming out of the esc and the extension so the extension wouldnt come off. also i fixed the leds. the previous owner wired two 10mm leds in series with a rx plug, i cut the plug off and attached a 9v battery harness and a switch. the also had four 5mm leds wired to somekind of control board and to another rx plug. this one all i did was shorten the wires for the front leds. any feedback from you guys/ girls would be great! Sent from my iPod touch using Tapatalk |
02-19-2013, 12:47 PM | #2 |
right now im running this with a dx3c, hopefully that will be switched to a 4pl today. im also going to work on moving the battery up front. Sent from my iPod touch using Tapatalk |
02-19-2013, 06:29 PM | #3 |
Quarry Creeper Join Date: Jan 2012 Location: Durango
| Re: c0bra's wraith
Looking good
02-19-2013, 09:34 PM | #4 |
02-20-2013, 07:31 AM | #5 |
Quarry Creeper Join Date: Sep 2010 Location: t(._.t)
| Re: c0bra's wraith
Looking good. This build should be just in time for the new VP Currie axles. |
02-20-2013, 07:36 AM | #6 |
02-20-2013, 08:13 AM | #7 |
| Re: c0bra's wraith |
02-20-2013, 11:58 PM | #8 |
i relocated the battery to the front and moved the esc to the rear. ill post pics in the morning. Sent from my iPod touch using Tapatalk |
02-21-2013, 08:20 AM | #9 |
under the hood. esc location battery wires. the on/off switch was removed when i got this so i wanted to make the wires easy to get to Sent from my iPod touch using Tapatalk |
02-25-2013, 09:29 PM | #10 |
i picked up some alluminum from the hardware store this afternoon and tried to make my own roof panel. i think it turned out pretty good, i decided to cover it with a parma carbon fiber decal. im also going to hinge the hood. and eventually make side panels. i may try a hood, but i may just pick up one from carter fab. Sent from my iPod touch using Tapatalk |
02-25-2013, 09:53 PM | #11 | |
Quarry Creeper Join Date: Sep 2012 Location: Orange County, CA
Sent from my iPhone 5 using Tapatalk | |
02-26-2013, 10:36 PM | #12 |
another update! in between classes today i was able to run to the hardware store again and pick up some 1/4 inch cable mounts to use as a hood hinge. they are a little small but after using part of the wraith cage, pliers and a lighter they are fine. almost jeep wrangler angle: set the wraith in its roof to see how far it opens (using rustler wheel and tire to help keep the hood off the ground) also while i had it apart i cut another piece of alluminum to make a rear tray. with flex shot (rustler tire and passenger seat) Sent from my iPod touch using Tapatalk |
03-16-2013, 07:25 PM | #13 |
im thinking about adding 2 interior lights (would go in front of seats), some rock lights and head and taillights. with doing something like this plugged into a drifter led harness what do you guys think? Sent from my iPod touch using Tapatalk |
03-16-2013, 09:36 PM | #14 |
Newbie Join Date: Mar 2013 Location: Snyder
| Re: c0bra's wraith
looks sweet bro - keep us updated man
03-17-2013, 05:38 AM | #15 |
Rock Crawler Join Date: Sep 2008 Location: Nashua,NH
| Re: c0bra's wraith
Looking good keep it coming.
05-14-2013, 07:47 PM | #16 |
im thinking about doing the fast back cage mod with axial links but i couldnt find a definite size. does anybody know what size link you need to go from the center bar to the back of the cage? Sent from my iPod touch using Tapatalk |
05-14-2013, 08:58 PM | #17 |
Pebble Pounder Join Date: Mar 2013 Location: Olivet
| Re: c0bra's wraith
Not sure the size but stock wraith lower links fit, what ever they are.
c0bra's wraith - Similar Threads | ||||
c0bra's cc01 | c0bra | Tamiya XC/CC01 | 21 | 02-20-2013 11:52 PM |
c0bra's TT01 build | c0bra | Non Crawler RC's | 13 | 01-22-2013 09:04 PM |
c0bra's.......wraith! | c0bra | Axial Wraith | 32 | 08-18-2012 09:16 PM |
c0bra's wroncho | c0bra | Axial SCX-10 | 64 | 12-19-2011 02:55 PM |
