02-19-2013, 05:45 AM | #1 |
Rock Stacker Join Date: Jan 2013 Location: Kentucky
| Lunges when letting off the steering
Got a castle link and reset my voltage going to the servo to 7.4v where it should be. Was playing with it a little bit and while it was just setting still and I would working the steering and it would lung forward just a little bit. Also if I had it turn all one way and I let off the steering and let it just go back to the center position it would do it. Any thoughts or experience with this. The only other thing I change with the castle link was my drag brake. It went from 50% to 100%. |
02-19-2013, 05:51 AM | #2 |
| Re: Lunges when letting off the steering
What electronics are you running? ESC, servo, etc.
02-19-2013, 06:09 AM | #3 |
Running the stock esc And controller and I am running a castle bec with a savox 2274sg servo.
02-19-2013, 06:10 AM | #4 |
And a 55t axial brushless motor
02-19-2013, 06:13 AM | #5 |
| Re: Lunges when letting off the steering |
02-19-2013, 01:40 PM | #6 |
That is affirmative on unhooking the red wire. How ever I did not know the axial motor was brushed. I thought it was brushless. I have been running the bec for about 3 weeks with no problems but I had the voltage set at stock because I did not. Have the Castle link. |
02-19-2013, 02:32 PM | #7 |
I have the same servo in my Exo. The only solution I found to fix the glitching was to lower the BEC voltage. Try lowering the BEC voltage by .2 volts until the glitching is gone. I ended up in the 7.0v range. Also check to make sure that all of the grounds (black wires) are connected together. Not having all of the grounds connected together can also cause glitching. Last edited by k7zpj; 02-19-2013 at 02:34 PM. |
02-19-2013, 08:33 PM | #8 |
Just curious why it cause the motor to lunge. Maybe because it is digital?
02-19-2013, 09:28 PM | #9 |
02-19-2013, 09:34 PM | #10 |
It was really noisy before I raised the voltage.
Lunges when letting off the steering - Similar Threads | ||||
Just letting you know. | ah_5500 | General Scale Talk | 2 | 11-15-2011 03:25 PM |
Letting the Smokes out | Dragon51 | Newbie General | 7 | 06-17-2010 03:53 PM |
