02-19-2013, 07:26 AM | #1 |
Newbie Join Date: Feb 2013 Location: ATx
| CenterDrive Axle Housing RC4WD.com
Are these worth the cahs... not that the $200 is alot considering it comes with the actual axles and link mounts, but I figure it helps with torque twist as well as I want to upgrade to aluminum housings anyways. Also, the only ones RC4WD carry are rears, but they should fit both front and rear right? Aluminum Rear Centered Axle Housing for Axial Wraith (Black) |
02-19-2013, 07:33 AM | #2 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
| Re: CenterDrive Axle Housing RC4WD.com
I have the rear center axle and the offset front one. I like them, check out the thread "getting closer" by me there are pictures there
02-19-2013, 01:10 PM | #3 |
but does the rear one fit front if I wanted to?
02-19-2013, 01:24 PM | #4 |
Not sure.. you would have to have some sort of part for the servo to mount to. Look on rc4wd and find out
02-21-2013, 08:08 AM | #5 |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
| Re: CenterDrive Axle Housing RC4WD.com |
02-21-2013, 08:13 AM | #6 |
I'm not using the centered housing, but I'm planning my rear steer out right now. CMS with the servo hidden in my TSC tool box and 3 link. An axle mounted servo wouldn't allow for hardly any travel, and your servo would be hitting the cage all the time. In my case at ride height it would bottom out on the cage. So IMO CMS and 3-link is the only way to go.
CenterDrive Axle Housing RC4WD.com - Similar Threads | ||||
Using a front axle housing on your rear axle | nstn8 | Axial XR10 | 2 | 10-25-2011 07:32 AM |
problem with rc4wd straight axle housing. | pavel | Newbie General | 0 | 04-07-2007 02:29 PM |
