02-20-2013, 09:48 PM | #1 |
Quarry Creeper Join Date: Jan 2013 Location: Julian, CA
| Rear Frame chop?
I'm liking the look of the rear cage being cut back. No 2 seem to be exactly the same. If some of you guys could post pics with your chop job and explain what you did, where you cut and what you used to do the mod, Id appreciate it.
02-21-2013, 06:20 AM | #2 |
| Re: Rear Frame chop? used a hack saw to chop the back off then a grinder with sanding disc to smooth it out then dremel with chansaw sharpening stone to finish it up |
02-21-2013, 07:58 AM | #3 | |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
| Re: Rear Frame chop? Quote:
02-21-2013, 08:02 AM | #4 |
Quarry Creeper Join Date: Aug 2011 Location: Antioch by a rock!
Here's my version Use the lower links that came in the kit. They fit perfect. Requires some tube trimming to keep the width right.
02-21-2013, 08:03 AM | #5 |
Here's mine. Used a piece of shrink wrap so it matched the rest of the cage. |
02-21-2013, 08:04 AM | #6 |
You could also hit up Bill from BGR Fabrication and get a full KOH cage. |
02-21-2013, 08:10 AM | #7 |
So what are the aluminum tubes you guys are using? Lower links look cool |
02-21-2013, 08:17 AM | #8 |
I just used some old AX10 links I had laying around. You could make the pieces out of the part of the cage you cut off. That's what I did at first.
02-21-2013, 08:39 AM | #9 |
I made the links with solid 3/16 steel and revo ends. Got a use the tools I have on hand. |
02-21-2013, 09:27 AM | #10 |
| Re: Rear Frame chop? |
02-21-2013, 09:39 AM | #11 |
Newbie Join Date: Nov 2012 Location: Midlands, UK
| Re: Rear Frame chop? There's my take on it. just a case of warming up and bending it down. |
02-21-2013, 09:56 AM | #12 |
^Wish I would have done mine that way. I didn't think of that at the time though.
02-21-2013, 10:02 AM | #13 |
Quarry Creeper Join Date: Jan 2010 Location: Lunenburg
Here's mine, used a Dremel with a cut-off wheel and a drill. All stock cage pieces. |
02-21-2013, 10:11 AM | #14 |
^ That thing is very nice. I've always wanted to get that body for my Wraith.
02-21-2013, 10:19 AM | #15 |
Rock Stacker Join Date: Jan 2012 Location: Vancouver
^^2nded. The mesh and diamond plate bed cover look really good. Did you cut a section of cage between the B and C posts and just move the back of the cage forward? Its one of the better rear-cage chops I've seen.
02-21-2013, 11:33 AM | #16 |
This is about the best pic I have showing the cage mod. Pretty much just moved the back part of the cage forward, removed the "V" brace and shortened the top side bars. You can see where I added screws in the back section of cage to tie it to the top side bars. Pretty easy mod. |
02-21-2013, 11:41 AM | #17 |
Thanks for posting the pic, I can see exactly what you did now.
02-21-2013, 12:31 PM | #18 |
Lol. I know I'm awesome. Jk ;)
02-21-2013, 05:32 PM | #19 |
Rock Crawler Join Date: Aug 2012 Location: Etowah
| Re: Rear Frame chop? Isyeskeert's Black Betty Fastback Wraith! I chopped off the rear posts, and heated the existing top section of frame with a heat gun. Then, I found some 4mm screws to screw it down in the corner. It acts as a shock tower brace too! |
02-21-2013, 05:44 PM | #20 |
Pebble Pounder Join Date: Aug 2009 Location: Orygun
Rear Frame chop? - Similar Threads | ||||
Who can build me a truggy frame that will bolt to an scx10 or fulll frame? | mtgrizzlymn | Newbie General | 4 | 07-04-2012 11:14 AM |
"Rap Chop" featuring Vince from ShamWOW (Slap Chop remix) | wrx-n-ktm | Chit Chat | 5 | 04-29-2009 08:40 AM |
