02-21-2013, 07:25 PM | #1 |
Quarry Creeper Join Date: Nov 2008 Location: NorCal
| Ultimate G6 Wraith Build?
What would your winning combo consist of? Don't be shy, spend it like it was Monopoly $ , but try to keep it somewhat realistic and within some sort of budget! I'm looking for fresh, nearly invincible, highly functional, not too-ridiculously over-priced,... Perfection |
02-22-2013, 10:37 AM | #2 |
Pebble Pounder Join Date: Jan 2010 Location: Reno
| Re: Ultimate G6 Wraith Build?
Simplicity is key! I'd run a 3300kv pro4 and a mamba max pro with 2 hitic steering servos for rear steer with a spectrum dx3e and waterproof receiver as for running gear all vanquish internals for the axles with C's, knuckles and steering parts. Robinson racing transmission internals And MIP drive shafts. Top that of with vanquish links and HD ring and pinions with 3s 5300mah gens ace battery's and a castle creations BEC. Then make it look however you want
02-23-2013, 01:53 AM | #3 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
Running my third G6 tomorrow but my setup is as follows Full RRP trans internals T Maxx shafts Sidewinder w 45T motor 50/50 sprung Big Bore shocks Universals in front diff ProLine TSLs on motoworx beadlocks. Savox servo- Need to upgrade this because the wheels are so heavy but the voltage regulator helps I like this set up cause its light weight, not complicated and doesn't have any fancy aluminum axle stuff to get hung up on. It also does not have any lights |
Ultimate G6 Wraith Build? - Similar Threads | ||||
The Ultimate RTR Wraith | meinthe73 | Axial Wraith | 1 | 01-19-2013 05:22 PM |
This would be the ultimate FJ build | neillarson | 2.2 Scale Rigs | 8 | 10-07-2010 01:34 PM |
