03-03-2013, 05:47 PM | #1 |
| so i had the need for speed and tons of power
as some of you know my wraith is 6s capable and i have been running mainly 2 and 3s crawling latly well today i had the need for speed. had planned to build a huge step up jump on my dirt pile so i strapped on two 3s 2200s to creat a 6s 2200. was going to get a vid but bashed around getting used to speed and power drag brake was turned of and main shes fast with the boggers the hook uop very well. itl coming out of slidding turn and punch the throttle and it flips over offcourse i have no vid to share because i had the camera in my pocket to get ready for the jump. but before that the rear end stopped driving then the front end stopped. kinda dumbfounded because i have robinson metal gears in the tranny. tore the tranny down and all is good there no slop no missing teeth nothing so i look at the axles. ring and pinion seem fine but it appears the locker is brokent or stripped. whats funny is i bashed around on the front axle only and it also quite im assuming its also the locker. im thinkinging this will be homebrewed fix. picturing a welded ring gear ust like my 1:1 rig more to come when i look closer at the lockers |
03-03-2013, 05:59 PM | #2 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: so i had the need for speed and tons of power
Stock lockers? If so yeah I bet you trashed them!! |
03-03-2013, 06:11 PM | #3 |
ohh yeah there trashed aliright, they were getting pretty sloppy before today. inner driveline flanges are fine
03-03-2013, 06:26 PM | #4 |
| Re: so i had the need for speed and tons of power |
03-03-2013, 06:37 PM | #5 |
bout to hit the buy button on set of hotraceing spools.
03-03-2013, 06:44 PM | #6 |
researching the vp locker or spool or whatevert you wana call it and it looks to be a pressed two peice unit. so the inner can absorb colinera movement. just from the description im going with the hr one peice spool. vp put some big words in there to make a few sales and thats it |
03-03-2013, 06:50 PM | #7 |
The vp lockers are the shit. I just installed them earlier this week. By far the best and strongest looking unit I've seen. And yes, it absorbs a ton of the movement.
03-03-2013, 07:46 PM | #8 |
Well I was won't be buying them hot racing is a one piece spool VP has inner and outer something or other and costs twice as much.
03-03-2013, 09:10 PM | #9 |
Quarry Creeper Join Date: Apr 2012 Location: Marietta
My hr lockers have held up just fine to a pro4 on 4s. I'll spend my extra money on something else vp for the wraith |
03-03-2013, 09:18 PM | #10 |
Through research I see no reason why VP would be any better but cost twice as much.
03-04-2013, 05:56 PM | #11 |
Two hr lockers are on the way Also eyeing the stock locker for a redkneck garage fix. Plastic screws up my welding it planns. Maybe some screws through the side of carrier |
03-04-2013, 07:30 PM | #12 |
03-04-2013, 07:42 PM | #13 |
Hr lockers ftw!
03-04-2013, 08:35 PM | #14 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
HR lockers are great, just purchased 4 for 2 of my trucks and will be buying some more to throw in a couple other sets of axles I have on the bench.
03-04-2013, 08:41 PM | #15 |
they sure look like theyre tuff from the pictures i found on the net. one single vp locker is a few bucks less then two hr's. theres also a handfull of other lockers not mentioned often on this site that looking pretty dang good. cant think if there names now. quick question. im looking into upgradeing to max shafts because there suposebly stupid strong for the money. so far ive found the crawler inovation 5mm outputs but theyre 40 bucks. ive found some 1/8 to 5mm pinion adapter that might work. i coulda swore a few weeks ago the subject came up and someone posted a actual 4mm-5mm output adapter(maybe it was the 5mm-6mm for the max shafts?) ive got a local traxxass dealer so it would be super hand and cheap to run some emaxx or t maxx shafts thanks |
03-04-2013, 08:43 PM | #16 |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
03-04-2013, 08:46 PM | #17 |
so your saying everything is awesome but that stuff?
03-04-2013, 08:46 PM | #18 | |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
| Re: so i had the need for speed and tons of power Quote:
03-04-2013, 08:52 PM | #19 |
03-04-2013, 09:02 PM | #20 |
the crawler innovations 5mm outputs are 46 bucks. max shafts yokes are 5mm with flat that needs drilled out. hmmm i wonder if i just drilled it to 4mm http://www.crawlerinnovations.com/in...mart&Itemid=80 hmmmmmm say there bolt on but the shaft is 4mm vs 5mm. now wondering if 1mm even matters with the cross pin through it. maybe they rubb the spur cover to im sure theyd self clearance or easily be fixed with dremel or grinder. im going to pick the shafts and yokes up tommorrow and see what happends Last edited by evan03; 03-04-2013 at 09:13 PM. |
so i had the need for speed and tons of power - Similar Threads | ||||
Lost power and speed after installing aluminum gears | Aionism | HPI Wheely King | 10 | 05-25-2010 08:30 PM |
Losi Lipo Works On Flight Power/Thunder Power Balance plate?? | fa1rch1ld | Electronics | 0 | 01-18-2010 11:46 PM |
Thunder Power 1350 Pro Power 30c review | Just Zach | Electronics | 35 | 09-04-2009 09:12 AM |
EVX speed control power? | mtnbkerman | Traxxas Crawlers | 3 | 07-30-2005 03:24 PM |
