03-11-2013, 01:15 PM | #1 |
Pebble Pounder Join Date: Jan 2011 Location: Hayden
| VP Chassis Mounted Servo Question
I am running the vp cms kit with the panhard kit and a hitec 7950th powering the steering. When completely flexed out with the drivers side tire up and the passenger down my servo will not turn to the passenger side. I am running a cc bec at stock setting. is it not enough voltage to power over the weight. Do i need to turn up the bec. Because from what i've read the hitec 7950th should be ample power.
03-11-2013, 01:48 PM | #2 |
Quarry Creeper Join Date: Dec 2012 Location: Cottage Grove MN
| Re: VP Chassis Mounted Servo Question
I have the same VP set up and the Hitec 7955 TG I dont have a BEC though. With my truck at full flex I can still trun my wheels full travel both ways. The settings on my servo are all stock and my ESC settings are all stock as well.
03-11-2013, 02:04 PM | #3 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
I have the same servo and it has plenty if power. Get the castle link if you don't have it already and try adjusting the voltage.
03-11-2013, 03:02 PM | #4 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
Yes stock voltage from CC BEC is way too low! You have to increase it to the max rating of the servo, whether 6V or 7.4V. Get a CC Link for sure!
03-11-2013, 06:04 PM | #5 |
Well went to lhs after work and picked up the castle link. Going to turn it up in a little bit. Let you know results
03-11-2013, 06:07 PM | #6 |
Rock Crawler Join Date: Oct 2012 Location: Vermont
I'm running the same servo with the same panhard/chassis mounted servo set up. Mine does the same thing, I think it's an inherent issue with the CMS when the suspension is flexed.
VP Chassis Mounted Servo Question - Similar Threads | ||||
Frame mounted servo question. | arctichorse | 1.9 Scale Rigs | 8 | 11-26-2012 07:37 PM |
CR-01 Chassis Mounted Servo | Landcruiser 110 | Tamiya CR-01 | 8 | 07-30-2012 02:26 PM |
chassis mounted servo??? | savagebeast | Axial Wraith | 4 | 05-04-2012 11:12 PM |
chassis mounted servo help? | luis | General Crawlers | 4 | 08-24-2008 01:47 PM |
Chassis mounted servo question... | Stallion1967 | General Scale Talk | 2 | 06-29-2007 08:27 PM |
