Thread: Sluggish Steering servo
Old 03-25-2013, 11:55 PM   #1
Default Sluggish Steering servo
So I've been searching for hours now... and haven't find my problem.
I'm running a stock AE2, 5000mah 3s 35c hyperion, castel bec, HH 35t brushed and a hitec HS-7955TG steering servo.
I haven't been out in awhile as it's still winter, last time out I had no problems. I put my battery into storage mode if it's not in use for 2 days.
So I fully charged my battery and went out for 5 min's in a bit of slush and my steering is non responsive, sluggish and random at best.
I've plasti-dipped all my electronics and submerged it in the past with no problems.
Any and all help is greatly appreciated
Thanks Chris
Nefarious Wraith is offline   Reply With Quote
Old 03-26-2013, 12:27 AM   #2
Default Re: Sluggish Steering servo
plstidip Water proofing is far from perfect. Its what I use but you have to understand. What worked yesterday may fail today... The wet slush may have killed off your servo.
Cougar503 is offline   Reply With Quote
Old 03-26-2013, 12:59 AM   #3
i agree sounds like a failing servo.
OGXXXOG is offline   Reply With Quote
Old 03-27-2013, 09:52 PM   #4
So I tried running my wraith again... the steering seems to working a bit better but is still gets stuck at full left steer.
My new question is; is it possible to salvage this servo? Either by drying it if it's still wet? Replacing the circuit bord? or Using the titanium geers in a cheeper servo of the same type?
Thanks Chris
Sluggish Steering servo - Similar Threads
Steering Servo/Dig Servo Questions YJJPWrangler Electronics 5 02-02-2011 10:59 PM
Mamba max, 11.1 1350 mil 25c, 5955tg steering servo, 5645mg dig servo BEAU Electronics 5 01-21-2009 02:36 PM
Sluggish, loss of torque?? Gearing Qs? Barillms Axial AX-10 Scorpion 3 10-30-2007 03:03 PM
sluggish axle woodymaxx General Crawlers 0 09-05-2006 02:18 PM
