03-27-2013, 06:04 AM | #1 |
Quarry Creeper Join Date: Mar 2009 Location: Independence,KY
| C hub question
I'm running strc c hubs on my wraith and I'm not very happy with how they fit on the axle ends. I've replaced the self tappers that hold them on with some m3 machined screws and they still come loose. The stock c hubs have the notches on the inside all the way across the chub but strc's are just half way and I think that's a big reason they always come loose. Looking for some c hubs that fit tight like the plastic ones. Do the axial or vanquish fit tight and are made with these notches all the way across? |
03-27-2013, 06:45 AM | #2 |
I wanna be Dave Join Date: Sep 2005 Location: *
| Re: C hub question
Axial or VP would be excellent choices I run the HR CHUBS with VP Knucks with no problems of either coming loose |
03-27-2013, 07:00 AM | #3 |
| Re: C hub question
Considering just upgrading all my Front end parts from strc to vanquish. The holes in my axles for the chubs arnt stripped yet, worried that it will lead to that though. |
03-27-2013, 08:06 AM | #4 |
Quarry Creeper Join Date: Jan 2013 Location: Spokane
| Re: C hub question
I have axial c hubs and knuckles and the c hubs are really tight! I haven't had anything come loose on either truck and I beat on them hard!
03-27-2013, 09:50 AM | #5 |
Pebble Pounder Join Date: Nov 2012 Location: Stoke on trent , England
| Re: C hub question
MY VP ones were very very very tight fitting , Nearly took a rubber mallet to them Jack. |
03-27-2013, 10:01 AM | #6 |
| Re: C hub question
That's very good to hear about the vp and axial c hubs. Idk who else is running strc but they seem like to me there just isent enough contact surface, very loose fitting
03-27-2013, 11:46 AM | #7 |
Rock Stacker Join Date: May 2012 Location: Kelso
| Re: C hub question
You can get the vp stage 1 kit witch is knuclks chubs and rear lockouts for $100 its a great deal and you can't go.wrong with vanquish
03-27-2013, 01:54 PM | #8 |
| Re: C hub question |
03-29-2013, 07:00 PM | #9 |
| Re: C hub question
Extremely happy with the fit and finish on this vp stuff. Strc steering links still on. Do I need to clock my c hubs forward for the vanquish titanium links to clear or what? As it sits now, the vp links wouldn't work at all. Crappy iPhone pic |
03-29-2013, 08:53 PM | #10 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: C hub question Your VP should work with the c-hubs in the position you have them now. It looks like the correct angle. |
C hub question - Similar Threads | ||||
Hub Question | GravelDuster | Axial SCX-10 | 0 | 02-06-2013 01:47 PM |
C-Hub Installation Question | GrimJeeper91 | Axial Wraith | 15 | 02-13-2012 07:16 PM |
C-hub question | gac1983 | HPI Wheely King | 1 | 02-24-2009 12:04 AM |
question on hub size in mm | 12flex | General Crawlers | 1 | 05-19-2006 02:55 PM |
