03-31-2013, 09:50 AM | #1 |
Newbie Join Date: May 2012 Location: Buffalo
| Product infomation
RE: http://www.hot-racing.com/index.cgi?par ... 1C01;c=623 Good morning and Happy Easter! I have a product question to ask all of you. Has any of you ever used this item for you Axial trucks? How does it handle for you while it's in your axles? While in high speeds or crawling speeds? Are you using a brushed or brushless motor? If you are using a brushless motor,how high is the kv rating? Does this item has a fill hole to add your diff oil or grease? |
03-31-2013, 04:56 PM | #2 |
| Re: Product infomation
Depending on price it would be a worthy upgrade. It'll keep the stock steel locker from spinning like it ends up doing in the plastic diff housings. For $15 though you can get the Hot Racing steel spool that completely eliminates the part you have pictured in your post. It's probably been around a long time though. I personally haven't used it so that's all I can say about it.
Product infomation - Similar Threads | ||||
New Axial Product??? | biggin69 | Chit Chat | 12 | 02-21-2010 10:55 PM |
product testing | CadToChrome | Michigan | 11 | 10-12-2008 06:40 PM |
