04-06-2013, 01:16 PM | #1 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
| R2j link help
Installing them on my wraith right now and when I put the uppers on it makes the suspension bind and will not flex at all. Anyone have any problems with these at all? I'm have rc4wd axles but I wouldn't think that would matter. There starting to piss me off. |
04-06-2013, 02:23 PM | #2 |
| Re: R2j link help
Well I tried to use just the r2j uppers and axial lowers and it binds and I tried r2j lowers and stock uppers and it still binds...... Looks like the r2j links are just a little bit shorter than stock..
04-06-2013, 02:50 PM | #3 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: R2j link help
Yes, I posted a comment about these links elsewhere. I went to install mine the other day, and they bind at every attachment point. I didn't want to clearance everything so I ordered the bent rod ends from RC4WD.
04-06-2013, 02:59 PM | #4 |
| Re: R2j link help
Well I sent him a pm and waiting to hear back from him
04-06-2013, 03:19 PM | #5 |
Quarry Creeper Join Date: Mar 2009 Location: Independence,KY
| Re: R2j link help
I hope this gets cleared up. I just ordered uppers for my wraith kit build
04-06-2013, 04:57 PM | #6 |
| Re: R2j link help
are the link ends straight. if so you gota clerance the belly pan. i made made a set for myself, basicaly the same thing as r2 links. i adjusted lower exackly the same lenth and uppers exackly the same lenght. uppers and lowers are not the exact same lenth. not even a hint of binding with my links i think id get the caliper out and start checing link lenghts ounce you have the belly pan clearanced ohhh another thing i did was have to slightly clearance the link that sits underneath the motor because the revo rod ends was rubbing it. if you have pro for or other bigger motor you may need to check this Last edited by evan03; 04-06-2013 at 05:00 PM. |
04-06-2013, 05:14 PM | #7 |
Rock Crawler Join Date: Jul 2012 Location: Grand rapids
| Re: R2j link help
I got a full set for my wraith had no issues at all bolted right up , like a glove
04-06-2013, 05:55 PM | #8 | |
| Re: R2j link help Quote:
04-06-2013, 05:58 PM | #9 |
| Re: R2j link help |
04-06-2013, 06:00 PM | #10 |
| Re: R2j link help
jimmy rig or not my wraith works as good as best of them at a fraction the cost that motor most likly isnt near big enough to cause any link intereferance words on the subject almost mean nothing. photos and vid of this binding might be worth a million unsaid words Last edited by evan03; 04-06-2013 at 06:02 PM. |
04-06-2013, 06:00 PM | #11 |
| Re: R2j link help
I've sent him 2 Pm's now and haven't heard back yet. And he has been on here a couple times since I sent them....
04-06-2013, 06:03 PM | #12 |
| Re: R2j link help
also when where revo links the same as stock axial links??
04-06-2013, 06:05 PM | #13 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
| Re: R2j link help
Ive made a few sets just like R2J's, and besides clearancing the skid like stated, had no binding at all. Shon will get back with you, give him time, hes a great vendor. Make sure all your rod ends are straight, not twisted unequally as well. |
04-06-2013, 06:07 PM | #14 |
| Re: R2j link help
photos please. at this point im assumeing end user error. at least untill some real info is given on the matter |
04-06-2013, 06:08 PM | #15 |
| Re: R2j link help What I meant is that they are we're supposed to work and function as good as oem parts. If you want to make your own links then good for you. He wanted a set of wheels and tires I had for sale so I traded him for a set of upper and lower links. The r2j links have revo ends which should make no difference at all. I think the length is off which I already said before. I don't need to use a caliper to see that they are off.
04-06-2013, 06:09 PM | #16 |
| Re: R2j link help |
04-06-2013, 06:12 PM | #17 |
| Re: R2j link help
Here's a pic. The r2j one is definitely shorter if that matters
04-06-2013, 06:14 PM | #18 |
| Re: R2j link help
Have you installed sll R2J's links at once? From your post sounds like your mixing them with other brands. Not that it should matter but Im curious. Im assuming your shocks arent sticking or drive shafts binding, correct? |
04-06-2013, 06:17 PM | #19 |
| Re: R2j link help I tried all r2js at first them I tried mixing them with the axial ones and no difference. The shocks are binding when I try to flex it. The shock wants to bend when I push down on any corner. Both the front and back compress straight down no problem. And no the drive shafts are fine...
04-06-2013, 06:18 PM | #20 |
| Re: R2j link help
he makes and straight and bent links. wich did you get? you could stop talking and wipp out your phone and take a few photos |
R2j link help - Similar Threads | ||||
R2J 4 link truss installed | Mega Fattie | Axial SCX-10 | 3 | 12-13-2010 09:41 PM |
R2J 4 link truss mounting question | liftmys10 | Axial SCX-10 | 3 | 02-24-2010 08:43 AM |
New lower link and skid setup thanks to R2J! | 801FuNk801 | Axial AX-10 Scorpion | 7 | 07-22-2009 11:28 AM |
