Thread: rx?
Old 04-06-2013, 08:42 PM   #1
Default rx?
I've got a spectrum sr3300t, i have to connect the bec to aux, the esc to the throttle, the steering to the steering, where can i connect the led's safely?
Thanks
cmnyj28 is offline   Reply With Quote
Old 04-06-2013, 09:38 PM   #2
Default Re: rx?
Leds can be connected to any empty channel. With me I only have 3 channels so it is channel 3.
ZippoMan is offline   Reply With Quote
Old 04-06-2013, 09:42 PM   #3
Default Re: rx?
Here is the manual for your RX http://www.spektrumrc.com/ProdInfo/F...structions.pdf
Old 04-06-2013, 09:52 PM   #4
Default Re: rx?
You can plug your external BEC into the Bind/RS port then use AUX for the LEDs.
Old 04-06-2013, 11:10 PM   #5
Default Re: rx?
I did read the manual and it's not a big help unless you want telemetry.
I was thinking about the RS, I wasn't sure what it meant so I plugged in LED's there, they work just fine..
THanks
