04-11-2013, 08:51 AM | #1 |
Rock Stacker Join Date: Mar 2009 Location: Tacoma
| Help with motor choice on RC4WD AX2 2 Speed. Gear ratios provided
So using the specs from a stock SCX10 tranny and going with what I know as far as what a 35T looks like with a 2.6 Ratio trans, I need to figure out what size motor to run. The new tranny is 32pitch so I need to figure what my largest spur and smallest pinion visa versa so I can figure what my ranges are. Now I have an SC10 with a 14/87 pinion /Spur and running a 35t and the tranny is 2.6:1. This new two speed is almost 5:1 but the high gear seems at 1.78:1 Doing the math further, I"m currently at a 16.1 : 1 final ratio on the SCX10. The new two speed and its current gearing would put me at 7.2 : 1 and 20.2 : 1 as final ratios. SCX10 : 14/87 = 6.21:1 times that by 2.6 and I get 16:1 final Wraith : 15/60 = 4:1 so 4 X 1.78 = 7.12:1 and 4 X 5.05 = 20.2 :1 the difference is 2.83 I'm happy with a 16:1 w a 35 Turn on 3S. So what brushless motor would I need to make me happy with a 20:1 ratio? Also I should redo this maybe with a different Spur/pinion combo. Put me in the middle of the range so I have some wiggle room. I just haven't been able to figure out what fits. RC4WD AX2 2 Speed
04-11-2013, 09:15 AM | #2 |
| Re: Help with motor choice on RC4WD AX2 2 Speed. Gear ratios provided |
04-12-2013, 10:13 AM | #3 |
Thank you ussprinceston Ask a technical question around here and its crickets. Post the 1,000,000th wraith build and its a 10 page thread. Does anyone have an ide on what turn/KV motor I should run? Guess I'm going to try the 13.5 Redline I have laying around. |
Help with motor choice on RC4WD AX2 2 Speed. Gear ratios provided - Similar Threads | ||||
Motor Choice for Warith with RC4WD 2-speed tranny | Colgout | Axial Wraith | 5 | 09-01-2013 09:55 AM |
Ax2 2 speed tranny | 04zrx | Axial AX10 2nd-gen | 2 | 02-13-2013 06:30 AM |
Rc4wd ax2 2 speed bearing's | Jacksprogis | General Crawlers | 11 | 12-13-2012 02:59 PM |
