04-13-2013, 11:37 PM | #1 |
Rock Stacker Join Date: Jul 2011 Location: fresno
| panhard what does it do?
I just installed chassis mount servo with panhard. I have no idea what it is for? Chassis twist? Help please
04-14-2013, 01:21 AM | #2 |
Rock Stacker Join Date: Feb 2012 Location: Kelso,wa
| Re: panhard what does it do?
Well the servo goes on the chassis for scale looks. If you were to keep the four link up front, you would get bump steer. So one upper link comes off. Now the panhard link gets bolted into place to locate the axle.
04-14-2013, 08:36 AM | #3 |
Take it off and drive. Youl then see what its for
04-14-2013, 08:46 AM | #4 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
Lets take a Jeep's steering for an example. A Panhard (or trackbar) travels width wise across the frame and axle. If you installed the kit without the panhard, you will instantly notice that you loose a ton of steering and that your front axle will move side to side. With a Panhard, You have centered your front axle as well as having a connecting rod to help keep it from moving side to side. Why does Jeep have a 4 link with panhard front and rear? The answer is still unknown and kindof stupid if you ask me. I think because the Jeep engineers, engineered the link geometry so poorly, they added a panhard to band-aid the problem. If you buy a Toyota link kit for the front from All-Pro Offroad, Marlin Crawler or Trail-Gear, It will always be a 3 link with panhard like what you see with the Wraith. Technically, when you install VP's kit, you'll still have a 4 link suspension system. You just have relocated one of the upper links to do another job. You shouldn't have a problem with this, but make sure that the Panhard and Drag link are in line with each other to help reduce bumpsteer. http://www.quadratec.com/Assets/Know...teering(1).jpg |
04-14-2013, 09:50 AM | #5 |
Pebble Pounder Join Date: May 2012 Location: Sherwood Park
There are two types of 4- link setups. Parallel and triangulated. A triangulated 4-link controls lateral movement of the axle by forming a triangle with the upper links. Parallel 4- link system has links that are parallel links. With this system, the axle has nothing limiting lateral axle movement. To hold it in position. A panhard (track bar) is used to control lateral movement. The difference is that triangulated 4-link allows for less link wrap-up during extreme articulation, which makes it ideal for rock crawling rigs. The downfall is that this only works with an axle mounted servo, or hydraulic steering on a 1:1. Although parallel 4-link has less articulation, it gives a lot more tuning options, and is ideal for higher speed rigs. A three link setup with a panhard is a modified 4-link, so you can run a cms. The reason for this setup is because the steering link makes an arc during compression. This would cause the steering to turn. The panhard eliminates this steering affect by laterally moving the axle in an identical arc the steering link travels. This setup allows for pretty similar articulation as a 4-link but gives scale looks for most trucks. Last edited by project_mayhem; 04-14-2013 at 10:04 AM. |
04-14-2013, 10:30 AM | #6 |
| Re: panhard what does it do? |
04-14-2013, 02:02 PM | #7 |
Also there is a video right on vp's website that says exactly what the panhard does.
04-19-2013, 12:10 AM | #8 |
Thanks to all! Big help.
panhard what does it do? - Similar Threads | ||||
Need for a panhard? | Armistice | General Crawlers | 13 | 09-04-2012 08:06 PM |
Panhard | PECO | Axial Wraith | 3 | 12-09-2011 05:23 AM |
what does panhard mean? | z71baja | Newbie General | 3 | 11-06-2011 09:03 AM |
Panhard ? | rottenbelly | General Scale Talk | 2 | 01-02-2010 09:27 PM |
2 link with panhard? | Flatty | Tamiya Clod Buster | 2 | 07-16-2004 12:51 PM |
