10-17-2017, 10:44 AM | #1 |
Rock Crawler Join Date: Oct 2015 Location: Kristiansand
| Help with ST Racing Concepts Wraith Aluminum V2 Steering Knuckle
I have these new knuckles together with the STRC c-hubs and aluminum steering links. But I don't understand how STRC intend the drag link to be mounted together with the tie rod. On top of each other with a spacer inbetween? Or tie rod under the knuckle arm? Does anybody have a picture of these mounted? Sent from my SM-G930F using Tapatalk Last edited by tjohanne; 10-17-2017 at 11:44 AM. |
10-17-2017, 12:42 PM | #2 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
| Re: Help with ST Racing Concepts Wraith Aluminum V2 Steering Knuckle
Huh? What's the difference? If both links fit above, do so, if not - drag link above, tie rod below.
10-17-2017, 12:57 PM | #3 |
No, they don't fit well above with STRC's own steering links. And either above or below, at extreme steering angle it looks like the balls will be twisted out of the joint. There is somehow too much angle on the knuckle arm for the ball joint to handle. Also, I am surprised that the tie rod should hang so low. I don't know if the picture really catches the 'problem. Maybe it's alright. I just wondered if anybody had a picture of these mounted up. Sent from my SM-G930F using Tapatalk Last edited by tjohanne; 10-17-2017 at 01:02 PM. |
10-17-2017, 01:17 PM | #4 |
Tie rod below gives extreme toe in. Sent from my SM-G930F using Tapatalk |
10-17-2017, 01:31 PM | #5 |
Toe in is fixed by adding a washer or two between rod and rod end, making it longer. Anyway, that's the way I run my Xtra speed knuckles and Incision links. Also couldn't clear the wheels when both rod ends were mounted above, even with thinner rod ends I had lying around.
10-17-2017, 06:15 PM | #6 |
You've got them swapped...left on right and vice versa. Steering arms should be towards the top, not the bottom. That will fix your toe in issues as well (for the most part - see below) Servo link goes on top using a long screw, and the drag link goes on the bottom of the knuckle and then secured with a nut. Attach the drag link to the bottom of the other knuckle with a shorter screw. Mine is set up here with CMS, but it's arranged the same if you can make it out. Had better pics, but you can thank photobucket for that. The STRC kit does induce a few degrees of toe in. Good for SMT10 trucks, but not so much for the wraith - a 3mm spacer on either side of the drag link puts it back to parallel. Last edited by OSRC; 10-17-2017 at 06:17 PM. |
10-17-2017, 06:31 PM | #7 |
looks like the chubs are also upside down... not positive though...
10-17-2017, 07:07 PM | #8 |
Newbie Join Date: Jan 2016 Location: Southern California
Yup they look upside down. Edit, same as swapping left and right as I think about it. |
10-17-2017, 07:55 PM | #9 |
The c-hubs are fine, it's just the knuckles that need to be swapped.
10-17-2017, 08:07 PM | #10 |
| Re: Help with ST Racing Concepts Wraith Aluminum V2 Steering Knuckle |
10-17-2017, 08:35 PM | #11 |
Lulz, I didn't even see they're upside down.
10-18-2017, 02:58 PM | #12 |
10-18-2017, 03:13 PM | #13 |
Just for kicks, rotate the chub 180* and leave the knuckle like it is...
10-18-2017, 03:25 PM | #14 |
I think I've fixed it by extending the tie rod and making my own drag link. Seems to me that STRC's own steering link kit simply doesn't fit their V2 knuckles. Only their V1 knuckles. Annoying. Sent from my SM-G930F using Tapatalk |
10-18-2017, 03:26 PM | #15 | |
| Re: Help with ST Racing Concepts Wraith Aluminum V2 Steering Knuckle Quote:
Sent from my SM-G930F using Tapatalk Last edited by tjohanne; 10-18-2017 at 03:32 PM. | |
10-18-2017, 03:32 PM | #16 |
Ok, now I see what you mean. Huh, that is strange. You could flip the C hub, but that would cause all kinds of issues. I guess flip the knuckles back to how you had them originally and mount both rods on top....see how that affects the toe as well. Might want to shoot your first pic over to STRC and see what they say. There are no pics of them mounted that I can see anywhere and no directions on the site of course. I have no idea why they would make a knuckle that way - maybe they have a reason. (edit: - I see you have already done so! lol) |
10-18-2017, 03:58 PM | #17 | |
I also reacted to the fact that there are no pictures of them mounted up. c-hubs and knuckles seem to work very well now, but I will ask STRC what's up with the steering links and lack of pictures/instructions. Sent from my SM-G930F using Tapatalk | |
10-19-2017, 01:59 PM | #18 |
Quarry Creeper Join Date: Feb 2014 Location: NNJ in the sticks
Only thing I'd suggest is to flip the bolts if possible. If they have the head on top and you loose the nut on the bottom it might stay together. With the head on the bottom there is a better chance of loosing the nut and bolt.
10-20-2017, 08:29 AM | #19 |
RCC Addict Join Date: Oct 2014 Location: UK
The knuckles look to be completely wrong by design.
10-20-2017, 09:13 AM | #20 |
Agreed. I'd be curious to hear their reasoning for moving the steering arm down the knuckle.
Help with ST Racing Concepts Wraith Aluminum V2 Steering Knuckle - Similar Threads | ||||
ST Racing Concepts STA80073BK aluminum steering links | JKJEDI | Axial Wraith | 0 | 11-13-2012 09:34 PM |
ST Racing Concepts aluminum steering upgrade help? | PIAA | Axial Wraith | 15 | 04-20-2012 01:37 PM |
ST Racing Concepts Wraith upgrade parts??? | 2-shot | Newbie General | 13 | 03-16-2012 07:08 PM |
hot racing steering knuckle users | mhflies | Losi Mini-Rock Crawler | 4 | 12-31-2011 08:31 PM |
ST Racing Concepts aluminum steering knuckles | brokeitagain | Axial AX-10 Scorpion | 9 | 06-27-2009 09:06 PM |
