06-18-2013, 07:42 PM | #1 |
Quarry Creeper Join Date: Jan 2007 Location: Shingle Springs
| 48 hour Wraith
With Axialfest this weekend and my parents deciding to join me for the weekend I decided my Dad needed something to drive. So I stopped at R/C Country and picked up an Axial Wraith for him to run in the Terra X race. Hopefully I can get it built before Thursday morning. Aww crud. BRB. I need to go get a star so I can post up some pics. There. Got my star. Motor -- Tekin ROC 412 2300KV ESC -- Tekin RS Pro or RS Gen2 (opinions?) Batteries -- 2500mah 3s Steering servo HS7954SH and depending on what ESC I end up using I may also have to add a CC 10A BEC MIP drive shafts Ti tie rod and drag link Stage one C hub, knuckle, and lockout kit. Last edited by 65BAJA; 06-19-2013 at 09:42 AM. |
06-18-2013, 07:53 PM | #2 |
Pebble Pounder Join Date: Dec 2011 Location: Ohio
| Re: 48 hour Wraith
Sounds like a challenge, keep us posted!
06-18-2013, 07:57 PM | #3 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
Go ahead and get the bec while you're buying..that way you won't come across any issues and be in a pinch to solve them quickly..sounds like you guys will have a great time! -sent from my smarter than me phone |
06-18-2013, 08:20 PM | #4 |
| Re: 48 hour Wraith
Diffs done until I find out if VP has a stage 1 kit in stock.
06-18-2013, 09:09 PM | #5 |
| Re: 48 hour Wraith
Ok, I'm on my mostest favoritest step in assembly. Shocks. YAY! There are 3 sets of pistons. A, B, and C. The instructions don't really say which one to use. Any hints? I was going to use B pistons unless there is a better way to go.
06-18-2013, 10:12 PM | #6 |
| Re: 48 hour Wraith
Shocks are done. I don't like Axial shocks very much. I believe a set of PL Powerstrokes are in my future.
06-18-2013, 10:32 PM | #7 |
Quarry Creeper Join Date: Jul 2011 Location: Sullivan
| Re: 48 hour Wraith
check RPPhobby they normally have the stage 1 kits in stock and most everything else you will probably need and super fast shipping as well
06-18-2013, 11:00 PM | #8 |
| Re: 48 hour Wraith
Links are done as well as one MIP drive shaft.
06-18-2013, 11:40 PM | #9 |
| Re: 48 hour Wraith
Transmission is done. Robinson steel idler and aluminum output gear. I want to put dig in this thing as I like the Hurst dig in my Dingo. Anyone have any experience with the Axial dig unit? |
06-19-2013, 12:45 AM | #10 |
| Re: 48 hour Wraith
Mocked up the motor and started assembly of the cage.
06-19-2013, 01:13 PM | #11 |
| Re: 48 hour Wraith
Made a visit to Vanquish Products.
06-19-2013, 01:27 PM | #12 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
| Re: 48 hour Wraith
Time's a tickin'! I'm sure you'll get it finished up by tomorrow!
06-19-2013, 07:11 PM | #13 |
| Re: 48 hour Wraith
Aaaaaaaaahhhhhh! Not enough time!
06-25-2013, 04:59 PM | #14 |
Rock Crawler Join Date: May 2012 Location: Upland
| Re: 48 hour Wraith
Did you get it done? You don't need a star to post pics if you host them somewhere else. You just need the star to host pics here on rcc Looks good. How do you like the 2300 roc12 ? |
06-25-2013, 05:04 PM | #15 |
| Re: 48 hour Wraith
I'll post some updated pics when I get home. It's running but I had to put a different radio in it that what I had intended to use. The Airtronics M11 receiver did not like being cooped up in the radio shack project box with the ESC and BEC. Intermittent glitching issues. The Futaba RX seems to be perfectly happy though. |
06-25-2013, 05:10 PM | #16 |
| Re: 48 hour Wraith It has loads of power and is plenty fast. I liked it enough that I ordered the 1800kv version to replace the 35T integy motor in my Dingo that I blew at Axialfest over the weekend. Just need to swap ESC's around from one of the other cars now.
06-25-2013, 07:14 PM | #17 |
| Re: 48 hour Wraith
Pics from before I left for Axialfest.
06-26-2013, 07:58 PM | #18 |
| Re: 48 hour Wraith
Drove it around a little yesterday. Still need to do some tuning with the ESC/motor. Werid problem where it cogs when on its side and the steering is full lock. Shouldn't be browning out as I'm using a CC BEC for power. The red wire from the ESC is disconnected. I do have the ESC in sensored only mode and I need to switch that to dual mode. Dunno if that is the problem or what. I have another ROC 412 coming for my Dingo so maybe I'll swap motors and see if that makes any difference. One other thing that happened is the slipper came apart. Dunno if I just didn't get it tight the first time or what but with the power of this thing I decided to go 32P anyway. I ordered a 32P Robinson slipper from RPP so all I need now is the SuperShafty Beefy topshaft and some hardened pinions. Edit: Re-set the ESC to Dual Mode and that seemed to have done the trick. Last edited by 65BAJA; 06-26-2013 at 08:51 PM. |
06-27-2013, 02:44 PM | #19 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
| Re: 48 hour Wraith
Congrats on YOUR new rig! LOL! We all knew it wasnt going to be your "Dad's rig"! Nice work so far.
06-27-2013, 07:59 PM | #20 | |
| Re: 48 hour Wraith Quote:
I thought the spare tire mod looked cool so here it is. It made the rear of the chassis a little flimsy IMO. So I might fab up a frame-shock brace/lowering bracket for the rear and lowering brackets for the front. Only thing left now is to paint the panels and get some line and a hook for the servo winch. Last edited by 65BAJA; 06-27-2013 at 08:02 PM. | |
48 hour Wraith - Similar Threads | ||||
4+ hour runtimes | SqueakyBum | Newbie General | 22 | 01-08-2012 08:22 AM |
had it an hour and broke it! | cummins1 | Axial Wraith | 13 | 12-29-2011 09:33 AM |
need to know in 1 hour. | rockunlimited2 | Tires and Wheels | 15 | 05-16-2010 08:55 PM |
Little over a hour left... | JasonInAugusta | Chit Chat | 3 | 01-07-2006 09:09 PM |
