08-08-2013, 11:51 AM | #1 |
Pebble Pounder Join Date: Jan 2013 Location: DENVER
| Jeep JK TTC CHASSiS Stiffy kit by DMG CMS front and rear by MG200 VP panhard 3 link front and rear Battery mount using stock tray trimmed down and bolted to the chassis rails, uses stock battery straps. Rear winch mount cut out of 22g steel Micro hood pin setup for 1/24 body clips -cut down McRC outer stub axle/Trekker outer stub axle threaded into RC4WD 2mm barrel nuts pressed into the drilled out hood screw holes. DRiVETRAiN Crawler Innovation trans output 6mm Stainless 5mm trans output Robinson Racing gears VP scx10 case OG ax10 output shaft no slipper BWD motor mount plate Kimbrough 32p 60t spur Associated 5mm 15T pinion MIP drive shafts ax10 MIP 6mm drive hub MIP Wraith long drive hub Traxxas 4x15mm screw pin RCP stainless locker Axial HD bevel ring and pinion VP knucks and chubs VP VVDs (rc4wds in photo) VP tie rod and drag link(1/4 photo'd now running 3/16) GH bearing caps HR lower shock/link mounts RC4wd Poison Spider diff cover Robitronic short horn HPI bushings 15x11x4 to replace pinion bearings X2 for 4WS Grinded these screws down for the lower link mounts to clear the fatty VP VVDs Last edited by WAFFLE; 09-16-2013 at 04:21 PM. |
08-08-2013, 11:52 AM | #2 |
| Re: Jeep JK TTC ELECTRONiCS Tekin Pro 4 3300kv Deans 12g wet noodle wire Castle BEC pro Castle MMP Futaba R2106GF 6-Channel Axial light controller Hitec 7954 servo winch Hitec 7950 steering servos RTV siliconed the set screws in Conformal coated the sensor boards and sealed the can with RTV silicone Conformal coated the receiver, light controller and the 2 7950 servo boards. Also conformal coated the mp3 player sitting there. and on the MMP and BEC Pro I conformal coated the boards first and then covered them in RTV silicone. Tied the front servo winch and the 3 racing rear winch into a Heyok HV winch controller on a switch. Making a servo winch with heyok controller and war pig spool: First drill out the servo horn screw hole to 7/32, you'll see why later, be carful not to drill all the way through, I went about a 3/8 inch deap, drill press makes this really easy, hand drill works too though. Pull the 4 screws on the bottom of the servo, slide the cases off, remember where all the ruber o-rings go inbetween the cases and the rubber washers for the screws, remember where there gears/pins go inside servo, unscrew the small phillips to the pot on the backside of the gear case. Then you will pull the pot from the gear case, then on the main gear( big gear) cut the pin on both sides flush. Now the main gear should spin freely, now using a m3x.06mod tap, thread the servo horn hole to fit the longer m3 screw needed for the war pig spool, It makes it real easy to thread it being able to spin the gear on the tap! now that everything in the servo winch is good mechanically, now time to strip the hitec electronics for the heyok controller. cut the ca glue holding the board to the case, carefully side the motor and board out the bottom, careful because they are soldered together. you must unsolder the board from the motor, then cut the rubber seal for the Rx wire leads off the board feed it onto the heyok winch controller wires, solder the wires to the motor, meshed the motor to the upper case gear, ca the motor in place, slap it all back together the way you took it apart and walla. iNTERiOR Electronics tray cut from styrene Wraith interior mounts to the wraith interior with threaded alum pipe Made a mount for the mp3 player I conformal coated for an in dash system. Used servo mounts on both sides to mount the New Bright JK dash to the chassis Some styrene fun Going to have blue backlighting in the dash The ribbon on the mp3 player screen wouldn't stretch so I had to make my own backlight The shifter works one of the buttons on the mp3 Axial dash logo Team36 seats Shane O'neill as my driver EXTERiOR Mickey Thompson Baja claws Mickey Thompson Sidebiter wheels Crawler Innovation 6.0 double deuce foams styrene back Reinforced for winch duty Viking fairlead mount Chopped up Dynamic Concepts Rubi body Painted the inside of the body silver cut the headlights out for real lights, markers will be transparent orange lenses outside painted white custom rear lights 3 racing diamond plate custom crusher corners you can see the winch switch behind the driver seat Last edited by WAFFLE; 08-08-2013 at 01:39 PM. |
08-08-2013, 11:52 AM | #3 |
| Re: Jeep JK TTC Last edited by WAFFLE; 09-14-2013 at 10:14 AM. |
08-08-2013, 02:46 PM | #4 |
| Re: Jeep JK TTC
wow. AMAZING build. awesome parts list, skills, and scale eye! |
08-08-2013, 04:30 PM | #5 |
Moderator Join Date: Jan 2004 Location: chicago
| Re: Jeep JK TTC
VERY nice! |
08-08-2013, 04:38 PM | #6 |
Rock Crawler Join Date: Nov 2010 Location: roanoke
| Re: Jeep JK TTC
Im in love!!!!!!!!!!!!!!!!!!!!
08-08-2013, 04:39 PM | #7 |
| Re: Jeep JK TTC
Awesome. |
08-08-2013, 05:49 PM | #8 |
Quarry Creeper Join Date: Oct 2004 Location: Cow crap flats
| Re: Jeep JK TTC
Very Sweet!
08-08-2013, 06:27 PM | #9 |
Rock Stacker Join Date: Nov 2012 Location: Australia
| Re: Jeep JK TTC
Nice job mate. |
08-08-2013, 06:40 PM | #10 |
RCC Addict Join Date: Sep 2011 Location: Peoria, AZ
| Re: Jeep JK TTC
Yea brother very nice job on that wraith..... |
08-08-2013, 07:01 PM | #11 |
Rock Crawler Join Date: Aug 2012 Location: 909 area
| Re: Jeep JK TTC
nice
08-08-2013, 07:28 PM | #12 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: Jeep JK TTC
Whoa.... You have been saving up for a while for this build! It looks great man! I wish I could see it in action..
08-08-2013, 08:01 PM | #13 |
Rock Crawler Join Date: Jun 2013 Location: Cincinnati
| Re: Jeep JK TTC
One of the most impressive interiors I have seen!
08-10-2013, 12:39 PM | #14 | ||
| Re: Jeep JK TTC Quote:
Thanks man Thanks Thanks Thanks Thanks Thanks Thanks Quote:
That's great to hear, that was the hardest part, took the most time, lots of trial and error, I went through 4 mp3 players, almost gave up on the whole idea many times but kept grinding away, this project collected dust for a good year at one point. Im pumped to hear all these great things from you guys, makes it all worth the time and money spent. I plan to get some more pictures up, as well as some video crawling and video of the in dash system. Im still thinking about making speakers, but my only hold off is they wont be waterproof, and this rig loves the water, so Im trying to find a way to have them unplug easy and be removable, but sound good so its not completely useless and can jam on the trail runs, LOL!! | ||
08-10-2013, 07:10 PM | #15 |
| Re: Jeep JK TTC
Music makes everything better! What bout speakers from head phones (maybe they make ones waterproof for workout) idk but ear buds in a small box would be easy to remove and look scale!
09-14-2013, 10:05 AM | #16 |
| Re: Jeep JK TTC UPDATES: Getting the submarine, oh I mean crawler ready for tomorrows Crawlspace TTC! I kept stretching the rear servo mount so I welded a plate across the bottom. Made a winch point for my front axle to suck the front end down on steep grades. Its been monsoon'n in crawlrado, so we went out for a night crawl to test the waters! should be good for the TTC! Last edited by WAFFLE; 09-14-2013 at 10:18 AM. |
09-14-2013, 06:17 PM | #17 |
| Re: Jeep JK TTC |
09-15-2013, 01:58 PM | #18 |
Quarry Creeper Join Date: Feb 2008 Location: Dawsonville, GA
| Re: Jeep JK TTC
That rig is looking great! A very intresting build. I'm really diggin the backlight gauges and in dash mp3 system. Keep up the good work! |
09-15-2013, 05:36 PM | #19 |
| Re: Jeep JK TTC
Looks killer. Wish I had 4ws. 1 question though. Why would you replace a 5mm output with another 5mm output? With the Pro4 the SS 6mm outputs are your best friend.
09-16-2013, 01:36 PM | #20 | ||
Finished 2nd in class 3 at the Crawlspace TTC this Sunday, was a great time in the rain! 09.15.13 The Crawl Space TTC @ Chicago Forks. | ||
Jeep JK TTC - Similar Threads | ||||
Who is the owner of this jeep? (jeromes 2008 TTC jeep) | scale4x4 | General Scale Talk | 1 | 06-06-2012 03:41 PM |
TTC jeep tj | madazz | 1.9 Scale Rigs | 28 | 01-16-2012 06:00 PM |
Jeep JK TTC Build | leosjeep | Redcat Crawlers | 2 | 05-08-2011 11:19 PM |
Jeep JK TTC Build | leosjeep | 2.2 Scale Rigs | 0 | 05-07-2011 06:58 PM |
TTC jeep tire | jeeper03 | Tires and Wheels | 8 | 10-26-2010 08:28 PM |
