08-29-2013, 05:42 AM | #1 |
Quarry Creeper Join Date: Sep 2012 Location: Seattle, wa
| Super Shafty 6mm outputs
I picked up a set of the 6mm trans outputs and the mip 6mm drive shaft couplers. I see the outputs have the hole in them like the stock outputs and the mip stuff came with set screws instead of the full length pin. Does anyone know what pin I need or does it use the stock axial stuff. Thanks Mike.
08-29-2013, 06:48 AM | #2 |
| Re: Super Shafty 6mm outputs
The stock ones are to small, you need to get some 4mm Traxxas pins. I think HPI even has 1 that will work. I'm bot sure why the MIP's are still only coming with grub screws. My Wraith MIP's didn't come with anything.
08-29-2013, 07:27 AM | #3 |
Quarry Creeper Join Date: Aug 2009 Location: Gamecock Country
Just got finished doing the same. You'll want traxxas part #5145. Theese will fit at the hub/output shaft only,unless running mip ax10 shafts like me,and then at pinion also. 6 pieces per pack,m4x2mm versus stock wraith m3x1.5mm. Hope this helps.
08-29-2013, 08:01 PM | #4 |
Perfect that's the info I needed. Thanks guys.
Super Shafty 6mm outputs - Similar Threads | ||||
6mm tranny outputs | Biscuit | Axial AX-10 Scorpion | 2 | 08-09-2009 10:51 AM |
Transmission with 6mm outputs? | MadForce | Newbie General | 3 | 04-20-2009 06:52 AM |
