09-15-2013, 06:15 AM | #1 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
| Advantages to a centered rear pumpkin?
Love the looks of the Wraith but confused why it doesn't have a centered rear pumpkin (diff housing). I guess they put an offset under there to ease drive shaft angles???? I'd like to see pix and hear your opinion if you have made the switch. Thanks guys |
09-15-2013, 07:38 AM | #2 |
| Re: Advantages to a centered rear pumpkin?
There are plenty of factory 1:1s that have an offset rear pumpkin (although none that I know of that have an axle that looks like the Dana style found in the wraith). There are also plenty of custom 1:1 buggies that use a front steering axle in the rear with an offset pumpkin. I like the offset pumpkin since it improves the ground clearance. If I was using ar60s in a more stock style scaler I would use a centered pumpkin but I think it fits right in with the theme of the wraith.
09-15-2013, 09:25 AM | #3 |
Rock Crawler Join Date: Apr 2007 Location: presKit
so they could use the same axle front and rear Sent from my SCH-I535 using Tapatalk 2 |
09-15-2013, 09:33 AM | #4 |
Newbie Join Date: Nov 2012 Location: Croydon
Same axle housing, different axles. The fronts are dogbone or universal and the rear axles are straight.
Advantages to a centered rear pumpkin? - Similar Threads | ||||
Rc4wd centered rear axle | otis683 | Axial Wraith | 2 | 09-15-2013 09:40 AM |
Centered pumpkin wraith axle? | driftdreamer06 | General Scale Talk | 9 | 10-07-2012 11:22 AM |
Using a vanquish brake rotor and a CFM centered pumpkin axle to make scale Rockwell? | Soulo747 | Axial Wraith | 20 | 09-06-2012 11:02 PM |
rear steer lockout advantages? | ASG#930 | Redcat Crawlers | 6 | 04-30-2011 01:19 PM |
