09-17-2013, 12:10 PM | #1 |
Pebble Pounder Join Date: Feb 2012 Location: NTG Racing - San Diego
| 12mm hex options
So, I got a really nice set of GripFab wheels that I got here, but the hubs will not work with the Axial hex, the two step centering stub is too long and the hub is not cut for the little step. I found that Axial has a hex with no stub, AX30427, and I should have no more problems but I was wondering, what else is out there, like in the clamp style. Also if any one knows of a hub that is compatible with the GripFab wheels that has that second step cut, please let me know. |
09-17-2013, 12:36 PM | #2 |
| Re: 12mm hex options
You could always just shave down the steps on your existing hubs. |
09-17-2013, 12:53 PM | #3 |
| Re: 12mm hex options |
09-17-2013, 12:56 PM | #4 |
| Re: 12mm hex options That is what I was going to do, I have three extra sets, but then I found the ones without the centering hub (AX30427) for less than $7. I always though that all 12mm hex were the same ID until I when to go put one, off my Slash, and found that it had a different center, that's when I started to wonder what other hexes are out there that are Axial specific.
09-17-2013, 01:07 PM | #5 | |
| Re: 12mm hex options Quote: | |
12mm hex options - Similar Threads | ||||
12mm hex spacers? | Gozer | General Crawlers | 0 | 01-28-2009 07:40 AM |
Are these 12mm hex? | dextermeth | Newbie General | 3 | 10-20-2008 06:40 PM |
