09-25-2013, 08:37 PM | #1 |
Newbie Join Date: Sep 2008 Location: Upper Deerfield
| Pan hard bar
What is the advantage of the pan hard bar suspension? I see several different models for the wraith but want to know the advantage before buying.
09-25-2013, 09:00 PM | #2 |
Quarry Creeper Join Date: Dec 2012 Location: SoCal
| Re: Pan hard bar
A panhard bar is a means of rigidly locating the axle lateraly while still allowing necessary suspension movement
09-25-2013, 09:16 PM | #3 |
Rock Crawler Join Date: Apr 2006 Location: Hartland, MI
| Re: Pan hard bar
The advantage, IMO, is mostly esthetic. Brings the servo into the frame and off the axle. I have less articulation than the 4-link setup. Still happy with it. =)
09-25-2013, 10:09 PM | #4 |
| Re: Pan hard bar
There is not really an advantage to the 3 link. When used with the cms kit it only improves the scale appearance, nothing else. With the 3 link I actually have more lateral movement do to the side to side sway during articulation. 4 link keeps the axle centered. But I have no complaints about either set up. Both function well and to me neither is better than the other.
09-26-2013, 04:27 AM | #5 |
| Re: Pan hard bar
Thanks for the info.
09-26-2013, 06:44 AM | #6 |
Pebble Pounder Join Date: Feb 2013 Location: El Dorado Hills
| Re: Pan hard bar
Its helps keep bump steer under control when using chassis mounted steering. It's more than just for scale appearance, it actually serves a purpose. There is more lateral movement with a 4 link, but you don't really see it when crawling.... UNTIL you move the steering servo into the chassis! Without a panhard, the wheels get turned a lot. When you install the panhard, it cuts the bump steer way down to almost nothing. Just like in a 1:1
Pan hard bar - Similar Threads | ||||
vp pan hard bar kit | vito | Newbie General | 3 | 10-22-2012 10:57 AM |
How do I make a Pan Hard Bar | neillarson | 2.2 Scale Rigs | 40 | 07-04-2011 10:23 AM |
pan hard bar | asw27x | General Scale Talk | 3 | 12-21-2010 03:04 PM |
third link and pan hard bar? | demonoid369 | General Crawlers | 4 | 10-26-2010 09:38 PM |
pan hard bar sketch???? | demonoid369 | HPI Wheely King | 4 | 10-25-2010 07:11 PM |
