09-26-2013, 10:31 AM | #1 |
Quarry Creeper Join Date: Jul 2013 Location: Toronto
| Got some new tires
Got some Proline Chisel's here are some of the before and after shots Still waiting on new rims to come in so i just put them on the stock wheels for now decided not to use the Proline foam as they are too big, just used the foam that came with the stock tires |
09-26-2013, 10:51 AM | #2 |
Rock Stacker Join Date: Mar 2013 Location: Newmarket
| Re: Got some new tires
I found that both the proline single stage foams and the stock ones were way too soft when crawling. They would wad up when you stuffed it into a rock.
09-26-2013, 04:38 PM | #3 |
Pebble Pounder Join Date: May 2008 Location: In Hendertucky
nice tires, did you test it out? how are they?
09-26-2013, 10:07 PM | #4 |
Gonna add some tech to the thread? At least the rig specs and some future plans.
09-27-2013, 05:51 AM | #5 | |
| Re: Got some new tires havent had a chance to test them outside as the tires are just sitting on the rims not glued as im waiting on some beadlocks Quote:
all I've done since I've gotten the wraith was added aluminum upper links, light bar and axial 2.2 wheels and Traxxas aluminum hold downs for the hood PVO_SRT4's Axial Wraith Last edited by pvo_srt4; 09-27-2013 at 05:54 AM. | |
09-27-2013, 07:18 AM | #6 | |
| Re: Got some new tires Quote:
09-27-2013, 08:40 AM | #7 |
Quarry Creeper Join Date: Jun 2010 Location: Carson City, NV
Honestly if I could do it again I would. I started out with cheap crappy electronics and have since spent hundreds of dollars finding a setup that works. ESC: Mamba Max Pro can run brushed or brusheless sensored or sensor-less. BEC: Castle 10 amp programmable program to 7.4V output Motor: If you want brusheless run a pro4 if you want brushed run a HH crawlmaster (note: I also ran the roc412 by tekin even though it's sensored it still didn't run very good at low speeds) Servo: Savox SB-2270SG run it off of 7.4V for 444oz/in of torque. |
09-27-2013, 11:41 AM | #8 | |
i will get a more crawler setup in the winter time. | |
09-28-2013, 09:41 PM | #9 |
A 1:1 tire with air will wasd up in the rocks.
09-29-2013, 02:51 AM | #10 |
Rock Crawler Join Date: May 2012 Location: Upland
09-29-2013, 07:50 AM | #11 |
| Re: Got some new tires |
09-29-2013, 09:13 AM | #12 |
Quarry Creeper Join Date: Jun 2013 Location: Tacoma
Looks good. Pro-Line makes fatty foam so people can trim it to their own specs. I actually "gear" cut mine and it helps with climbing and crawling. The trade off is that it drives a little silly on concrete but I dont spend much time on concrete. Good luck with your build! |
09-29-2013, 08:15 PM | #13 |
I've pulled my boggers off the bead with dang near no air. Sometimes you got pick a difrent line. To protect the tire
09-29-2013, 08:31 PM | #14 |
Pulling off the bead and or flat out damaging a tire is just a pita full scale. The thing about the Wraith is I will attack those sharp undercuts that I would avoid with my Jeep. If the foams are too soft then the tire will just ball up and cause it to stop rotating. This is not to mention the problems you run into on a side hill where the tire folds over on itself(usually a position you avoid in the full scale world as well lol.) |
09-29-2013, 08:39 PM | #15 |
Exackly
10-28-2013, 06:53 PM | #16 |
Newbie Join Date: Oct 2013 Location: Perham
Do you vent the tires or just the rims
10-28-2013, 07:05 PM | #17 |
I found that the Proline Chisel's worked a lot better using the Double Deuce foams from Crawler Inovations. I have 5.25T foams with the medium outer rings on my Wraith.
