Thread: Gearing Help
Old 10-04-2013, 02:58 PM   #1
Default Gearing Help
Just ordered a MMP speed control and a Tekin ROC 412 3100kv motor what is a ball park for the pinion and spur gear to me going, also how long will the stock drive shafts hold up
BLOWN HOWARD is offline   Reply With Quote
Old 10-04-2013, 03:39 PM   #2
A fair ratio at the pinion/spur is near 6:1, preferably 32p. The driveshafts won't last long with that combo. An insert in the male end will make it last a bit longer but will also possibly impede maintenance.
Meatwad is offline   Reply With Quote
Old 10-04-2013, 03:49 PM   #3
Default Re: Gearing Help
You will want to run 32p for the Spur and Pinion. I went with a SuperShafty Beefy Top shaft with the RPP #7856 Slipper 56T with 12T Pinion. I started out with a 54T 32p plastic spur but I broke the stock top shaft after a couple of packs.
The stock drive shafts didn't last much longer even with the drive shaft mod.
k7zpj is offline   Reply With Quote
Old 10-04-2013, 05:21 PM   #4
I am running the 54t traxxas slash spur gear and a 14t pinion (32p is a must)
No problems so far while running my 19t motor. However i did twist a driveshaft after about 12 packs through it. (probably half my fault) lol
rcguy is offline   Reply With Quote
Old 10-04-2013, 07:17 PM   #5
Another option would be the steel slipper/spur from RRP in 48 pitch. I run my pro4 3300 at around a 5:1. But could go all the way to4:1 just keep an eye on temps.
hatefulboy is offline   Reply With Quote
Old 10-04-2013, 10:10 PM   #6
Depending on the weight of the rig and tire size, with the Roc412 3100 56/10-11 is a good place to start. If it still gets a little warm start playing with different pinions and maybe a different spur.
crawler nut is offline   Reply With Quote
Old 10-05-2013, 07:56 AM   #7
I have the pro4 3300 in mine and run 56/14 with no problems. I run 2.2 tsl tires on aluminum wheels and it all runs pretty cool. Not sure on my weight though. I'm guessing 1.5 pounds more than stock maybe.
Tmaxxed is offline   Reply With Quote
Old 10-07-2013, 11:37 PM   #8
Anybody have the part number the the steel spur/slipper I need the 56 tooth one
Old 10-08-2013, 02:43 AM   #9
Robinson? #7856
Robinson Racing Products - Products and Pricing for TRAXXAS SLASH
Robinson Racing HP Slipper Unit 56T Gen 3 Slash
altd896 is offline   Reply With Quote
Old 10-08-2013, 10:11 AM   #10
Thanks got it ordered
Gearing Help - Similar Threads
gearing...? mhflies General Crawlers 1 07-24-2012 09:53 PM
Gearing Steve182 Tamiya CR-01 6 09-26-2008 10:09 PM
1.9 wk gearing? bigblazerboy General Crawlers 2 02-18-2008 05:31 PM
1.9 gearing? bigblazerboy HPI Wheely King 2 02-17-2008 12:47 PM
