01-02-2015, 08:14 AM | #1 |
Rock Stacker Join Date: Dec 2014 Location: South of columbus Indiana
| Wraith Kit
First package has arrived. Looking forward to this build. I have been out of surface vehicles for many years. [IMG][/IMG] Enjoy, John |
01-02-2015, 10:07 AM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: NW ATL
| Re: Wraith Kit
01-02-2015, 01:19 PM | #3 |
Quarry Creeper Join Date: Oct 2014 Location: Barre
| Re: Wraith Kit
Nice! I'm about to start the same build.
01-02-2015, 02:38 PM | #4 |
Quarry Creeper Join Date: Jun 2013 Location: South jersey
| Re: Wraith Kit
looks like a good start!
01-02-2015, 04:41 PM | #5 |
| Re: Wraith Kit
Thanks all! More packages arrived this afternoon! Will post when I get a chance :-) |
01-02-2015, 05:23 PM | #6 |
| Re: Wraith Kit
Ok, had to open my packages. Looking forward to trying out the crawlmaster 16t! I've never used a 5 pole motor before. Waiting on the rest of the stuff from VP to come back in stock.. Radio amd misc upgrades. Two more packages expected in the next few days. Enjoy, John |
01-10-2015, 12:56 PM | #7 |
| Re: Wraith Kit
I can't get this VP tie rod to clear the diff cover... all parts up front are stock kit parts except the VP tie rod and drag link. It's not the racing one either. Angled up above the diff it's worse than riding directly in front of it. Any suggestions? John |
01-10-2015, 01:03 PM | #8 |
| Re: Wraith Kit
I just realized I put "5 pole" LoL slot...
01-10-2015, 01:04 PM | #9 |
| Re: Wraith Kit
What about mounting the tie rod ontop of the steering arms? Then possibly some minor trimming to the diff covers' "ribs" if needed.
01-10-2015, 01:23 PM | #10 | |
| Re: Wraith Kit Quote:
I had put the tie rod above before (it clears lock to lock) but it seems that the drag link will bind at servo throw. I was holding off on adding the electronics till the end, but i guess I will mount the servo and see if it works freely or not. I was thinking that I was just missing something and it was an easy fix. Vanquish shows the tie rod on the bottom and the drag on top. it even states on the description: "Vanquish Products Titanium Steering Tie Rod for Axial Wraith. New version adds more adjustablilty at the rod end (does not rub Differential Cover when C-hubs are clocked). Direct replacement to fit stock and VP Wraith steering arms." The description sounds like plug and play.... Thanks, John | |
01-10-2015, 01:47 PM | #11 |
| Re: Wraith Kit
After installing the servo and horn, it appears that should work. Keeps the tie rod up and out of the way. Not a lot of room there. I will have to keep an eye on it so it doesn't bind. Still curious if others have had problems with this set up? Enjoy, John |
01-10-2015, 01:55 PM | #12 |
| Re: Wraith Kit
I'm glad you pointed this out - I had just installed mine on the VP knuckles. Hadn't checked the clearance, because I assumed that it would be perfect due to having the entire VP front end kit. It looks like if the casters are swung forward a bit it might allow for a little more clearance, but that gets into a whole different set of adjustments. |
01-10-2015, 02:03 PM | #13 | |
John | |
01-10-2015, 02:16 PM | #14 |
| Re: Wraith Kit
I'll definitely update after I get it all together. I had already moved on when I saw your post. I recall Harley doing something in a video (PS budget build???) with the link to get it to hold itself up. I'll do some searching and see if I can find it. |
01-10-2015, 02:25 PM | #15 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Wraith Kit |
01-10-2015, 02:35 PM | #16 |
| Re: Wraith Kit Holding the end of the link and pulling up or pushing down on the tie rod kind of "sets" position. I remember seeing that on his video and others. |
01-10-2015, 02:47 PM | #17 |
Newbie Join Date: Apr 2011 Location: ca
| Re: Wraith Kit i just finished building my kit, i got the rc4wd linkage, and i didnt have any clearance issues looks like the exact same links, maybe the VP doesnt have enough angle bent in it. the thing turns on a dime too!
01-10-2015, 04:29 PM | #18 | |
It does appear that the VP doesn't have enough bend in my case. John | |
01-15-2015, 09:32 AM | #19 |
| Re: Wraith Kit
Took it out for a test drive yesterday in my woods. I was nothing short of amazed! After 20 minutes of running the dry creek bed I headed for the steepest part of the revine that is washed out with scattered roots and branches. Couldn't get it stuck! Good times Put the body on today. I Enjoy, John |
01-15-2015, 09:34 AM | #20 |
| Re: Wraith Kit
Not sure why the 2nd pic didn't post.. |
Wraith Kit - Similar Threads | ||||
wraith rtr/builder kit , ax10 ridgecrest or scx10 kit hocho/dingo | xC Pirates | Newbie General | 9 | 06-09-2012 06:54 AM |
