10-26-2013, 10:44 AM | #1 |
Newbie Join Date: Oct 2013 Location: Traverse City
| Northern Michigan crawler build
Well, after watching my buddy bash his Wraith around my property a few times I figured it was time to get one for myself. And once I got it, I couldn't stop building it, so I thought I'd share my build. Its all over the place from homemade shock mounts to full stage 1 conversion kits. So far my purchases include- -(4) Integy T2 piggyback shocks -(4) Integy T3 lower shock mounts -(2) Integy T3 upper shock mounts (front) -Proline Crawler/Desert Light bar -Integy GT 12 light LED kit -(2) Axial High clearance aluminum links -(2) Integy type I diff covers -Integy stage 1 conversion for axial wraith I have also made a solid aluminum rear bumper and a lift for the front shock mount out of 1/8" aluminum flat stock. All parts ordered aside from the hi-clearance links are Integy lime green anodized. Most parts are still in the mail but here's a few shots of the first round of install. I also did a homemade modification to my drive-shaft as shown in an upcoming picture. I threaded a bolt into a male drive-shaft tube and removed the ends to make a solid sliding male connector, which is connect 2 female drive-shaft tubes connected at the tranny and axle. |
10-26-2013, 11:33 AM | #2 |
| Re: Northern Michigan crawler build |
10-31-2013, 04:34 PM | #3 |
Finally got myself a new spur and pinion set up. Trying out 84/14 for now. Also got my full conversion kit installed and snagged an anodized blue servo horn. Pics to come soon. Looking at getting a new motor and esc. any suggestions? looking for a good range of speed yet high low end torque. |
10-31-2013, 05:04 PM | #4 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
Holmes Hobbies and Team Brood are the two you are going to hear on here over and over again. I have had and used both. Both are GREAT and will rock your world. Holmes makes a motor specifically for the Wraith, even tells you what gears to run to keep the temps in check when running. What are you running for batteries? 3s 2s? |
11-10-2013, 10:30 AM | #5 |
right now i have a few 3000mA NiMH and i have borrowed my buddies 2s lipo several times
Northern Michigan crawler build - Similar Threads | ||||
Northern Michigan crawlers!! | Grinder0613 | Michigan | 10 | 10-23-2012 07:10 PM |
Northern Michigan Crawlers | Grinder0613 | Newbie General | 3 | 07-24-2012 11:17 PM |
Northern Michigan ? | chris4207 | Michigan | 8 | 12-03-2009 06:45 PM |
northern michigan crawlers | mgt crawler | Michigan | 5 | 01-26-2008 06:01 PM |
