10-31-2013, 10:07 AM | #1 |
Newbie Join Date: Aug 2013 Location: SE MA
| Recognize these Beadlock 2.2 Wheels ???
Anyone recognize these Beadlock 2.2 Rims ? Recognize these Beadlock Rims - R/C Tech Forums Are they still available? I heard that they may be RC4WD. Any pictures of what was in the front & rear center ? The outside ring would have a .98 max OD and have a .785 bolt circle Checking the RC4WD site I see that the 2.2 wheels are missing the Beadlok Wheel Hex or Pin drive plates. Similar to Z-S0187 or Z-S0268. I asked them if they have any with an 8 bolt pattern to fit these wheels. For now the axial drive hex's are pushed into the rear center hub of the wheel. It works but I would like to make it more solid. Thanks for looking ! |
10-31-2013, 10:22 AM | #2 |
Rock Stacker Join Date: May 2010 Location: Lotus, CA
| Re: Recognize these Beadlock 2.2 Wheels ???
They appear to be a TrailReady copy. Dan and Debbie at Mayhem Engineering make licensed TrailReady HD Beadlocks in 1.9 & 2.2 but they have a 6 bolt pattern on the hub. The products they produce are top notch for sure! Check them out. You may have to stick with a 6 pattern. Their web link is below Home Page |
10-31-2013, 10:33 AM | #3 |
those are RPP edition/ RC4wd 2.2 beadlocks with the optional thin rings. made many years ago. i have a set. they had a standard 12mm hex machined into the wheel on the back, and on the front they had a nut cover that bolted on the front of the wheel with the 8 screws. Last edited by STANG KILLA SS; 10-31-2013 at 10:36 AM. |
11-01-2013, 05:46 PM | #4 |
Thanks for the info & pic. I'm trying to find out if the motoworxracing covers will fit. I like the steering stabilizer....source for it? http://motoworxracing.com/?product=2...l-single-wheel see 2.2 wheels and wheel accessories Last edited by Massastan; 11-01-2013 at 05:50 PM. |
11-01-2013, 05:55 PM | #5 |
| Re: Recognize these Beadlock 2.2 Wheels ??? That one was probably made. Rc4wd sells some now. A couple lengths too. Edit. Wrong link. http://store.rc4wd.com/Superlift-Adj...mm_p_3517.html Last edited by Szczerba; 11-01-2013 at 06:04 PM. |
11-01-2013, 07:11 PM | #6 | |
| Re: Recognize these Beadlock 2.2 Wheels ??? Quote:
steering stab was make from TLT kit left overs. we made all our stuff back then from the left over tidbits from the "little gear" kits see Sz's post | |
11-19-2013, 03:33 PM | #7 |
Stang, you were correct. The Motoworx covers do not fit. Now I have 4 covers to hang somewhere. I decided to go with a different center arrangement. See... Wraith versus Rat - R/C Tech Forums |
Recognize these Beadlock 2.2 Wheels ??? - Similar Threads | ||||
Beadlock vs non beadlock wheels | Kocis715 | Tires and Wheels | 0 | 05-19-2012 05:16 PM |
