10-31-2013, 10:36 PM | #1 |
Rock Stacker Join Date: Sep 2013 Location: Prescott
| Gears for Axles
Getting ready to buy gears for my axles on my build. There are three different ones to choose from. Which ones would be best setup, should I mix them up or should I keep them the same front and rear. 38/13 36/14 43/13 Thank You Jeff |
11-01-2013, 03:38 AM | #2 |
Pebble Pounder Join Date: Sep 2013 Location: Mechanicsburg, PA
| Re: Gears for Axles
What pitch are these gears? Also what motor and battery set do you have? That is some info others may get to give you a proper gear assessment. I am going to run a Homes 13t CrawlMaster with 3s Lipo’s so pretty powerful. I went with a 32p 56/12. I also have 10, 11 and a 13 pinion to test out. |
11-01-2013, 03:42 AM | #3 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Gears for Axles
It depends. Dedicated crawler: 36 front, 43 rear. Trail running: 38 front, 43 rear.
11-01-2013, 06:49 AM | #4 |
Doh........ I feel like a ID10T....! :rolleyes: So you were talking differential gears. Your post makes total sense to me now. Sorry for my confusion. :confused: |
11-01-2013, 11:56 AM | #5 |
| Re: Gears for Axles |
11-01-2013, 12:00 PM | #6 |
11-01-2013, 12:36 PM | #7 |
11-01-2013, 01:33 PM | #8 |
| Re: Gears for Axles UD rear and stock front makes more sense than stock rear and OD front. More reduction in the axles takes stress off the drive line ahead of the axles and will further decrease torque twist. You want your torque multiplication to happen as late in the drivetrain as possible.
11-01-2013, 03:17 PM | #9 | |
After ruining 2 od gears in the front of mine, I simply run stock gear ratio in the front.. The ud and stock have lots of gear mesh, to where the od gears have very little teeth from pinion gear touching the ring gear. I even blew a set of od out of my 2.2s running a 13t Team pro crawl motor.. ridiculous power! | |
11-01-2013, 03:59 PM | #10 | |
| Re: Gears for Axles Quote:
11-01-2013, 04:11 PM | #11 | |
11-01-2013, 11:49 PM | #12 |
Pebble Pounder Join Date: Jun 2011 Location: Rio Brisbanero Australia
| Re: Gears for Axles
If you run overdriven in the rear and standard in the front you will find your wraith does much better donuts and sometimes thats more important than crawling |
11-02-2013, 02:59 AM | #13 |
| Re: Gears for Axles
Almost like standing on the brake pedal and your right foots on the floor. I've ran under drive rear over drive front axial and hr gears I've blown and warn out mylruplecsets. I'm now back to stock ratio on each end and can't tell the difrence |
11-03-2013, 04:28 PM | #14 |
| Re: Gears for Axles
Thank You for all the response everybody.
Gears for Axles - Similar Threads | ||||
Gears for berg axles | mustangboy_347 | EnRoute Berg | 15 | 12-15-2011 02:37 PM |
Axles & Gears | bluedragon436 | General Crawlers | 13 | 03-27-2008 08:48 PM |
possible 1/24 gears for axles | 500swmag | General Scale Talk | 1 | 09-14-2007 12:25 PM |
