11-09-2013, 09:29 AM | #1 |
Newbie Join Date: Jun 2012 Location: Kennesaw
| Wraith lower link replacement
I am replacing my stock suspension links with the VP ti links. I can't seem to get the allen screw that is inset into the skid plate to come out. I have loosened it and keep unscrewing but it won't slide out to allow me to pull the link end. Is there a trick to getting these screws out? |
11-09-2013, 09:56 AM | #2 |
Quarry Creeper Join Date: May 2012 Location: Italy
Keep on unscrewing and slightly apply a pull force outwards normally they would come out the slot.... - slim - |
11-09-2013, 10:00 AM | #3 | |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: Wraith lower link replacement Quote:
11-09-2013, 10:19 AM | #4 |
Thanks. That is kind of what I thought. I am using a small 1.5 Allen wrench. I may go get a new 1.5 tool with a better handle to help. I have a feeling the screw is completely unscrewed, I just can't get it to come out. |
11-09-2013, 12:45 PM | #5 |
Put side pressure on the screw with the link end
11-09-2013, 06:47 PM | #6 |
| Re: Wraith lower link replacement Please throw the little L wrench away if that's what you are using. Or at the very least save it for emergency use in the field. Get a decent driver with a handle. Apply side pressure while backing the screw out like the others have said and they will come right out. |
11-09-2013, 06:53 PM | #7 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
While unscrewing lift the tool a little so that the set screw can bite into the skid a little that should work.
11-10-2013, 03:35 PM | #8 |
yes ounce the threads end the screw is still way in there and the pressure from the link will help work it out as you continue to unscrew it
11-11-2013, 01:58 PM | #9 |
Rock Stacker Join Date: May 2010 Location: Lotus, CA
Or you can just smash the stock plastic misalignment spacer with pliers and viola!
11-11-2013, 02:09 PM | #10 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: Wraith lower link replacement |
11-11-2013, 02:14 PM | #11 |
Naw no hammers but if you're ditching the stock links just cut em off at the spacer and grab it with pliers and unscrew the grub screw. Works like a charm lol
11-11-2013, 08:11 PM | #12 |
This is a service part and needs to be serviced at times well that is if you actually run your wrairh. You are fubarred if you can't romove it. Good thing most dont run there's enough to wear links out. |
11-12-2013, 09:27 AM | #13 |
update They came out easy with the nice clean, new 1.5 tool. I may have been using a tool that was standard instead of metric, it felt like it fit, but didn't completely. The set screws are out, new VP links are in. |
Wraith lower link replacement - Similar Threads | ||||
replacement for lower rod end | tanakam24 | Losi Mini-Rock Crawler | 2 | 03-08-2011 06:52 AM |
