12-06-2013, 08:50 AM | #1 |
Newbie Join Date: Sep 2013 Location: Tacoma
| Looking to make my wraith Hex Drive. Verifying equipment..
So my wraith already stripped out a hub and i just dont want to deal with pin drive so i would like to go to hex drive. I have looked around a little bit and i will be going with vanquish products. are these the two things i need? hub how many of these will I need? Like do they come in packs of 2 or 1? Hexes only 1 of these unless you think i need an extra set. Thanks for the help guys! I would actually also like to know a good servo without going too expensive. I should probably mention i have the PSC version Last edited by drunkyoda; 12-06-2013 at 09:18 AM. |
12-06-2013, 10:59 AM | #2 |
| Re: Looking to make my wraith Hex Drive. Verifying equipment..
ok i have figured out most of this on my own so far haha. So i know i need SLW hubs with 12mm hexes. The only question i have is about the hardware... I know you need 4-40 but how long? I think I saw that Vanquish is using 4-40x1/2 but i'm not sure and that seems pretty long. |
12-06-2013, 12:38 PM | #3 |
Take wheels and hexes and to your local fastener store. Youl walk out with a boat load of bolts with plenty of spares. While your at it ask about bearings and put you a good bearing kit together. Ask about abec 5 bearings Savox 1230, 1268,1283, hxt10kg. Those are good reliable servos at a fraction of what the hitech have servos cost |
12-06-2013, 01:51 PM | #4 |
thanks for the info. I actually found out the 4-40x1/2 were the correct size and found them on lockeduprc
12-06-2013, 02:30 PM | #5 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
wrong hexes....vanquish hubs use Wraith hexes TowerHobbies.com | Axial Aluminum Hex Hub 12mm Black (4) just need a quanty (1)....comes all 4 in a pack. Consider used axial wheels, you may come out cheaper than vanquish hubs. Not to mention you have to know the correct size for the VP hubs when you buy. Just a thought. |
12-06-2013, 03:37 PM | #6 |
well these are actually the ones im getting. Same ones that Harley used on his weekly build. I think i will like the wider stance anyways. Thanks for the info about the hex nuts also. I had already figured that out though . so the list is. Vanquish SLW 475 hubs 4-40x1/2 hardware from lockeduprc axial hexes 12mm and as a bonus I am going to get some CI DD's |
12-06-2013, 05:20 PM | #7 |
IMO the wraith looks kinda goofy with wide offset rims. The axles themselves are plenty wide and when you bring the wheels in a little it looks MUCH better. If someone can verify they'd work, i would get the .225" hubs.
12-06-2013, 05:33 PM | #8 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
You could also use the shift hubs by lattice innovation. They are an aluminum version of the pin mount. I use them on vp wheels and they work great. Presenting Shifts, Lightweight n' Flexible Offset Hubs |
12-06-2013, 05:45 PM | #9 | |
| Re: Looking to make my wraith Hex Drive. Verifying equipment.. Quote:
12-06-2013, 05:52 PM | #10 |
Curious why you asked the question if you're imitating what someone else has done? Good luck and welcome to the addiction |
12-11-2013, 10:07 AM | #11 |
i didnt actually see Harley's video on this. and i wanted to see if anyone had any other opinions like the one above. If i dont get the VP stuff for xmas i will be getting the LI stuff.
Looking to make my wraith Hex Drive. Verifying equipment.. - Similar Threads | ||||
Which axle hex drive hub for vp slw's? | BubbaEinstein | Tires and Wheels | 3 | 11-25-2012 07:13 PM |
broke hex driver in drive shaft | m1009cucv | Axial SCX-10 | 5 | 05-23-2012 09:13 PM |
HOW TO - make 1.7 Brat [wagon] wheels for 12mm hex | pantablo | Tires and Wheels | 9 | 07-18-2009 01:53 AM |
Hex drive size? 10 mm ? | twbfab | General Crawlers | 4 | 12-28-2005 08:26 AM |
