03-26-2014, 05:16 PM | #1 |
Rock Stacker Join Date: Feb 2014 Location: Eastpointe
| What size tools?
Just got myself a wraith and servo went out! Soooo i figured id take apart some other random things and strip the pain the previous owner had done on things like the knuckles. So far it seems the wheels are 7mm socket? and then 1.5 and 2mm allens for most of the rest of it. Any thing else i may need? Can anyone suggest a good rc tool set? |
03-26-2014, 07:08 PM | #2 |
Newbie Join Date: Dec 2013 Location: Highlands Ranch, CO
| Re: What size tools?
I am finishing up the kit build, so far I have used: Hex drivers: 1.5, 2.0 and 2.5mm (I used a 2.0 power tip to partially assemble the cage) Nut drivers 7.0 (wheels and slipper), 5.5mm throughout, (5.0 only inside the shock) Tie rod wrench: 3.0mm (shock shafts) I bought a set of EDS Tools. So far I have been very happy. I had trouble ordering them in the US and ended up going with a place in Hong Kong. I had a good experience and pricing was good, I don't want to violate any forum rules so pm me if you want the name. |
03-27-2014, 07:42 AM | #3 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
Add and exacto knife, tweezers, small wire cutters, small needle nose pliers, a soldering iron(if you're unfamiliar how to solder, you should learn), and wire strippers. That will round out a really nice too kit |
03-27-2014, 08:56 AM | #4 |
Newbie Join Date: Oct 2013 Location: steep falls
i picked up a mini plier set at harbor freight tools for about $7. has been a nice addition, also a set of "T" handle allen head wrench's
03-27-2014, 02:50 PM | #5 |
Quarry Creeper Join Date: Oct 2011 Location: New Mexico
Get a cheap drill and bit driver set from Harbor freight. Remember some of the aftermarket parts you buy will use standard hex heads. The harbor freight bit set has them all x2. Dremel is nice. 4.5" cutoff wheel. 3mm taps are my newest purchase and are really all you need to make custom parts.
03-27-2014, 07:23 PM | #6 |
Rock Stacker Join Date: Jan 2014 Location: Reseda
Also get digital calipers from Harbor Freight
03-27-2014, 11:05 PM | #7 |
So much good info! I actually learned how to solder quite well years ago thank goodness! Im going to try and get a decent set of allens first .. something with handles for sure. Most of the other stuff i do have.
03-27-2014, 11:27 PM | #8 |
RCC Addict Join Date: Aug 2011 Location: Elkhart
| Just buy good stuff once rather than cheap stuff a couple times, allens are not an item you wanna go the cheapest route on. Get a good quality set of hex drivers and you will be happy with them and they will last you years.
03-28-2014, 09:58 AM | #9 |
Pebble Pounder Join Date: Jan 2013 Location: DENVER
I have really good success with integy hex driver set X22301, there ti-nitride coated, you can put the tips in a drill for faster use. They don't wear out fast like other driver tips, eflite, dubro, dynamite. basically comes with all the standard hex drivers: .050 1.5mm 2.5mm 1/16 (works on VP scale wheels micro hardware) 3/32 (fits 4-40 for vanquish wheels) 5/64 (same as 2mm) When the small ones break or wear, get lockedup.com cobalt driver tips, top notch tool steel! |
What size tools? - Similar Threads | ||||
Servo Armor...Standard Size or 7980 Size!!! | Chaotic Crawlers | Electronics | 2 | 07-26-2011 12:33 PM |
