04-07-2014, 03:35 PM | #1 |
Pebble Pounder Join Date: Mar 2013 Location: Olivet
| MIP's on wraith
if I add a long drive hub part no MIP11117 will it clear my spur gear cover with out trimming it ?? I have the AX10 shafts
04-08-2014, 09:40 AM | #2 |
| Re: MIP's on wraith
Yes. Just a FYI if you didn't already know, you can use these Traxxas Screw Pin 4x15mm Revo (6) to attach those ax10 shafts to the other side of the tranny and the axle outputs. Last edited by Jus; 04-08-2014 at 09:43 AM. |
04-08-2014, 03:14 PM | #3 |
| Re: MIP's on wraith
Thanks and yes I have the traxxas pins, the rear shaft is in.
04-08-2014, 04:15 PM | #4 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: MIP's on wraith
The MIP11117 still use the smaller Wraith sized pin. Mine cleared the cover when installed, but every tiny rock and stick got jammed in there. Had to trim the cover a bit to keep my sanity |
04-08-2014, 06:26 PM | #5 |
Quarry Creeper Join Date: Apr 2006 Location: sweethome
| Re: MIP's on wraith
Im using the AX 10 mips and had to trim a little but it gives you a bigger pin and they are cheaper.
04-08-2014, 10:13 PM | #6 |
| Re: MIP's on wraith Weird. I run the cover on all but one of my trucks and have never encountered that problem. and my Wraith especially has spent time crashing through the woods "off trail" |
04-09-2014, 08:02 AM | #7 | |
| Re: MIP's on wraith Quote:
MIP's on wraith - Similar Threads | ||||
MIP's on wraith | Mike5025 | Axial Wraith | 26 | 08-23-2012 07:41 PM |
Scx mip's on wraith? | CHOPPERMECH11 | Axial Wraith | 6 | 04-01-2012 01:46 PM |
MIP's are here! | Hellbilly | Axial AX-10 Scorpion | 107 | 07-07-2008 07:53 AM |
