04-14-2014, 02:13 PM | #1 |
Quarry Creeper Join Date: Dec 2013 Location: Central IL
| Dying wraith chassis or paint?
Before I go and put all the new goodies I have to finish up my wraith build, I really want the chassis to be gray or silver. Is it possible to RIT dye the black to gray ? Or does it need to be painted with a primer and then painted silver/gray? Sent from my SCH-I545 using Tapatalk |
04-14-2014, 03:03 PM | #2 |
Pebble Pounder Join Date: Nov 2010 Location: Simi Valley
| Re: Dying wraith chassis or paint?
Unfortunately, you can't dye black to another color. It would need to be painted instead.
04-14-2014, 03:15 PM | #3 |
Pebble Pounder Join Date: Mar 2013 Location: Olivet
but the paint scratches off pretty easy, looks good for a while
04-15-2014, 06:05 AM | #4 |
Thanks - I was wondering if you could Dye black another color. Didn't think that'd work. So I guess my best bet is to use a primer, then an over coat, followed by a clear. |
04-15-2014, 07:39 AM | #5 |
Newbie Join Date: Oct 2013 Location: steep falls
try krylon fusion paint, it adheres to plastic very well
04-15-2014, 11:59 AM | #6 |
Pebble Pounder Join Date: Feb 2004 Location: Born in a crossfire hurricane
2x that. They make paint the adheres better to plastic than your standard off the shelf spray paint. It's still paint, so don't expect it to work like a dye, but it'll last longer than regular rattle can. |
04-15-2014, 02:58 PM | #7 |
Thanks guys. I'll look into it. Sent from my SCH-I545 using Tapatalk |
04-15-2014, 05:15 PM | #8 |
Newbie Join Date: Apr 2014 Location: Dover
I would look into Plasti Dip, I've been thinking of trying it but it coats and protects the plastic and also changes the color, Looks like a solid deal! Coatings and Adhesives, Rubber and Plastic Coatings | Plasti Dip Interntional (Multi-Purpose Rubber coating) |
04-15-2014, 05:42 PM | #9 |
You realize that's a coating and not a paint. It will add bulk and weight to your rig, not to mention it will cover you cage with a soft grippy surface like you'd find on pliers and other hand tools. I wouldn't recommend this for a frame. But, it will obviously change the color of your cage, and if that's all you're looking for it'll work great.
Dying wraith chassis or paint? - Similar Threads | ||||
Need someone to paint my Wraith Blazer body | unclemikey1978 | Paint and Body | 7 | 08-04-2015 05:01 PM |
wraith chassis paint? | crazy nick | Paint and Body | 1 | 12-01-2013 02:39 PM |
New paint on Wraith | minicrawler1 | Axial Wraith | 3 | 07-01-2013 09:07 PM |
Remove paint from wraith tube chassis | t3yf5g | Paint and Body | 5 | 08-13-2012 03:42 PM |
wraith skins or paint ideas????? | dkchance74 | Axial Wraith | 19 | 08-22-2011 11:40 PM |
