05-17-2014, 03:32 PM | #1 |
Newbie Join Date: Feb 2013 Location: Westport, MA
| Stock Servo going Nuts HELP
Driving the wraith today an no big crashes (today) and all of a sudden the servo (stock) starts spinning really fast but not turning the main gear that the horn mounts on. So I took the servo off and looked at all the gear and non of them are broken put it all back and still doing it. What is going on? |
05-17-2014, 04:47 PM | #2 |
In the band for now. Join Date: Sep 2012 Location: roselle
| Re: Stock Servo going Nuts HELP
stripped servo horn maybey
05-17-2014, 05:09 PM | #3 |
Unfortunately it is a brand new aluminum horn. I wish it was that easy!
05-17-2014, 05:48 PM | #4 |
Quarry Creeper Join Date: Mar 2014 Location: Athens, Al
a friend of mines did that not too long ago and the guy at our hobby shop said it was something electrical making it constantly look search for center. Kind of like having a limit switch go bad or something of that nature i guess.
05-17-2014, 07:07 PM | #5 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
If you hear spinning, it could be that the motor pinion has come undone from the motor shaft. Just like the motor on your truck, servo motors have pinions. Perhaps its slipping. Also perhaps the gear directly off the motor stripped. They are very small and it only takes 3 teeth for the motor to slip. If that's the case just spin the gear 180°
05-19-2014, 11:01 AM | #6 |
Thanks guys for the input I took it apart again and there were some teeth that were stripped. I was able to take a pin out and rotate it 180 degrees and she is back up and running. I think the motor in the servo is a little weaker now than before but that is to be expected I guess with it being the stock servo.
Stock Servo going Nuts HELP - Similar Threads | ||||
alu servo horn for the stock servo (625WP)? | dbuus | Vaterra Twin Hammers | 1 | 07-09-2013 01:52 PM |
what size are the stock nylon wheel nuts? | GSRswapandslow | Losi Micro-Rock Crawler | 9 | 01-25-2010 03:55 PM |
What servo arms fit stock servo? | dave m | Losi Mini-Rock Crawler | 3 | 02-19-2009 11:54 AM |
What is the size/thread of the stock TLT bolts and Nuts? | TJ_Shunk | Newbie General | 1 | 08-10-2007 09:32 AM |
