05-20-2014, 07:06 PM | #1 |
Quarry Creeper Join Date: Jan 2012 Location: Durango
| For all my fellow 1.9ers...
Who runs a CMS and who runs Servo on Axle? and pics of your set up? I have currently been running a CMS set up and am having nothing but problems, I have torn my truck down to switch back to Servo on Axle.
05-20-2014, 07:19 PM | #2 |
Quarry Creeper Join Date: Dec 2005 Location: Orrington
| Re: For all my fellow 1.9ers...
I'm running mine on the axle. Didn't like the way the cms lined up.
05-20-2014, 08:56 PM | #3 |
RCC Addict Join Date: Aug 2007 Location: Seattle
I like steering. Refuse to even consider a chassis mounted servo.
05-21-2014, 05:07 AM | #4 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
I have an axle mounted servo on mine . It was easy to setup and had no problems . Works great for me so I have never tried a CMS setup . Badd's Fusion 1.9 Wraith with SCX10 axles |
05-21-2014, 05:41 AM | #5 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
I've got a cms on mine, it takes a while to sort it out but I wouldn't have an axle mounted servo as I don't like the look. What cms where you using and what problems did you have with it.
05-21-2014, 05:51 AM | #6 |
Quarry Creeper Join Date: Feb 2005 Location: Indy-Westside
I used the STRC mountwith a JC auto design axle truss. Running a 3 link/panhard setup with no issues or complaints.
05-21-2014, 07:13 AM | #7 |
Quarry Creeper Join Date: Sep 2012 Location: home
Im running a servo on axle as well but wouldnt mind figuring out a cms in the future. - Richard |
05-21-2014, 07:16 AM | #8 |
Rock Crawler Join Date: Jan 2010 Location: [loh-key-shuhn]
I use a VP CMS mount with the chassis side VP panhard mount. I use a Hand Bros axle bracket for the axle side panhard mount and the 3-link mount. Works great. The panhard bar fits down nice and tight on the axle. As with any CMS, you get some limitations with the steering throw depending on how the suspension is flexed. I run the shock bump-stops on the front shocks to limit the flex thus limiting most, if not all, binding issues.
05-21-2014, 09:10 AM | #9 |
I had VP cms and panhard and was using a level 3 axle mount since rc4wd was sold out of their scx10 axle mount, Maybe just using this JUNK level 3 crap for the axle mount it through off my geometry?
05-21-2014, 11:15 AM | #10 |
The only way I see them work is when they limit something like castor, shocks, or steering. Does anybody make a kit with a 6" or longer pan hard bar? |
05-21-2014, 11:22 AM | #11 |
Rock Crawler Join Date: Sep 2005 Location: Columbia, SC
05-21-2014, 11:44 AM | #12 |
Scx axles and zero Ackerman knuckles.
05-21-2014, 11:52 AM | #13 |
CMS, though I prefer axle mounted for strength and simplicity. Just ran out of room, so had to go CMS. Mine took some trial and error, but now works pretty good. Needs a longer servo horn and it'll be dialed in - can't quite get to full lock to the right though its so close i'm in no hurry to fix it. Modded Level 3 mount on the chassis, and just spacers on the axle itself - link bolts on the top of the 4-link mount. Nothing special required on the axle, and zero bump steer that I can detect. The steering link looks a little off, but it's just due to the angled rod end. Needed it to prevent some binding, the overall geometry is nice and square. Different angle with an older set-up Oh, and all the links were in my parts box, the mount cost $17 shipped. Easy Peasy. Last edited by OSRC; 05-21-2014 at 12:03 PM. |
05-21-2014, 11:53 AM | #14 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
Axle mounted....I don't have the wraith upper supports so I can't use any cms kits Sent from a rock |
05-21-2014, 05:24 PM | #15 | |
OK, I just tried this exact set up on my 1.9 except with a VP CMS, My panhard bar still hits top axles housing before its fully compressed? Quote:
05-21-2014, 10:43 PM | #16 |
Rock Crawler Join Date: Mar 2014 Location: Union City, CA
Axle mounted. Running t-rex 60s and 4 link F&R. Running LCC white spring shocks and I have no clearance issues, servo only touches chassis when I try to bottom out both front shocks evenly, and I do have to try as I have never accomplished it on a trail or in a creek. Just got done beating up my new tsl XL's and love my cog and stability, I build my trucks to play with on trails and in creeks. Not sure how many points a cms gets you in a comp but if you have a 1.9 wraith in one I'm not sure it's gonna save you. To each his own! ( they do look nice, not sure I would sacrifice function for it though) |
05-21-2014, 11:25 PM | #17 |
Quarry Creeper Join Date: Mar 2010 Location: SF East Bay
I've monkeyed with CMS/panhard setups quite a bit and one of the main things to consider when buying/making a CMS/panhard setup is to make sure that the servo link and panhard bar can follow a curve originating from the same central point, or as close as possible to it--otherwise you end up with a lot of bump steer. The second thing to consider is that the servo link and the servo arm need to be as close to perpendicular to each other in order to get almost the same amount of throw--meaning most setups need to have the servo arm pointed to the driver's side front wheel and have the linkage adjusted as necessary to maintain everything mentioned above. Last but not least, the closer to parallel the panhard bar is at your vehicles mid-travel point, the less you'll have to deal with the axle moving laterally--ideally, the axle should be at mid chassis centerline halfway through the suspension stroke--this is why I like the JCAD SCX10 axle truss/panhard mount/chassis mount, since it brings the panhard bar closer to parallel at most vehicle's natural ride-height.
05-22-2014, 03:28 AM | #18 |
05-22-2014, 07:20 AM | #19 | |
| Re: For all my fellow 1.9ers... Quote:
Exactly as above, try a bend in your panhard, or use a bit of a spacer on the Axle to lift it up. Just remember the 2 golden rules for the panhard and the steering link: -link length should be the same -links should be at the same angle (mounting point-wise) (or as close as possible) This was my first stab at it, can see the kinked panhard : | |
For all my fellow 1.9ers... - Similar Threads | ||||
Hello fellow ND crawlers | Ballistic17 | North Dakota | 15 | 03-03-2013 12:07 PM |
To all fellow RCCers... | braceysdad | Chit Chat | 19 | 10-13-2012 12:06 AM |
Need fellow crawlers.... | ax10 guy | Axial AX-10 Scorpion | 1 | 06-10-2009 01:52 PM |
What 1.9ers are these? | braceysdad | Chit Chat | 19 | 12-28-2007 06:35 PM |
