06-14-2014, 05:20 PM | #1 |
Rock Stacker Join Date: Apr 2014 Location: Mobile
| Quick Wraith Gearing question
Building my Wraith kit, and fixing to start on the transmission build. Using a CC MMP & HH 35 Turn Torquemaster Expert Pro. Want to have a transmission ration better suited for crawling, so I know I need something in the 5.X:1 range. Also, going to go ahead and go with 32 Pitch gears. Will a 10T pinion and 54 T spur be ok? (This will give me a ratio in the transmission of 5.4:1. Any fitment issues? Will this size be o.k. for the motor? Don't want to burn anything up. Thanks in advance |
06-14-2014, 05:28 PM | #2 |
| Re: Quick Wraith Gearing question
That should work fine but you should always check temps on new builds.
06-14-2014, 07:44 PM | #3 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
You will need a 1/8" to 5mm adapter to run a 32P spur with that motor. I am in the process of getting parts to convert my step fathers Wraith to 32P. I will be trying 60T spur and 14T pinion. It has the same HH 35T motor. http://www.amain.com/product_info.ph...Pinion-Adapter |
06-14-2014, 09:26 PM | #4 |
It bet that ratio runs very smooth. I run 56/14 and would like to step the pinion down to a 10 or twelve but my motor is touching the tray with the 14 a bigger spur will rub my driveline yoke. But yes always check temps. Each and ever rig is direct and all drivers drive did rent so what works for me or Bob may not work for you. |
06-15-2014, 08:45 AM | #5 | |
| Re: Quick Wraith Gearing question Quote:
06-15-2014, 12:35 PM | #6 |
| Re: Quick Wraith Gearing question |
06-15-2014, 12:40 PM | #7 |
06-15-2014, 03:00 PM | #8 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
Everything RC sells a 5mm 10T 32P pinion.
06-15-2014, 03:13 PM | #9 |
06-15-2014, 03:48 PM | #10 | |
Got a link? | |
06-15-2014, 06:32 PM | #11 | |
Huh, that's sweet that they make smaller pinions although cutting a motor shaft isn't high on my priority list. I haven't had any problems with my axial brand 11 tooth pinions in either 1/8 or 5mm flavor. | |
06-15-2014, 07:45 PM | #12 | |
06-15-2014, 07:53 PM | #13 |
Funny, that looks exactly like the HR pinions. |
06-16-2014, 06:58 PM | #14 |
Thanks all. I really appreciate the info/advice.
Quick Wraith Gearing question - Similar Threads | ||||
Wraith gearing question...please help | Robert51483 | Axial Wraith | 2 | 11-08-2013 07:36 PM |
quick/easy Axial EXO question, gearing | REV666 | Non Crawler RC's | 0 | 04-20-2013 05:25 PM |
Quick ? on motor/gearing. | JDeezie82 | Axial Wraith | 1 | 01-01-2013 01:02 PM |
New to the Wraith and to r/c in general, Hello and a quick Question. | Boostmeister | Axial Wraith | 11 | 03-22-2012 10:04 AM |
I need help on e-maxx gearing quick | bulletproofcustoms | Traxxas Crawlers | 2 | 06-08-2004 08:41 AM |
