09-09-2014, 10:50 AM | #1 |
Rock Stacker Join Date: Feb 2014 Location: peoria
| drive shaft ?
So my wraith has rc4wd punisher shafts but the yokes are traxxas and they are garbage. My wraith has a cc mamba max pro and stock wraith 20t motor. 2 minutes on flat surface on 2s lipo and *snap snap* the ends broke off. I checked the begginers guide and everyone seems to say go MIP but when I get the shafts I don't want to have to buy 3 other things just to get them to work. I want a metal drive shaft(not integy) that when I buy them and get them its just simply undo the screw pin things that are on the out drives andput the new ones on. I was looking at the junfac carbon steel ones, I know integy is metal and cheap but I haven't heard a lot of good about them. |
09-09-2014, 11:13 AM | #2 |
Pebble Pounder Join Date: May 2013 Location: kinzers
| Re: drive shaft ?
MIP all the way got mine and just assembled what come in the bag and good to go!!!!! very easy install!! top quality!! MIP all the way
09-09-2014, 11:48 AM | #3 |
Pebble Pounder Join Date: Mar 2011 Location: Wales,UK
| Re: drive shaft ?
Junfac are good too, maybe not quite as robust but lighter
09-09-2014, 04:54 PM | #4 |
Rock Crawler Join Date: Jan 2012 Location: middle TN
| Re: drive shaft ?
I wouldn't buy anything other than MIP.
09-09-2014, 06:15 PM | #5 |
Quarry Creeper Join Date: Dec 2008 Location: Santa Mira
| Re: drive shaft ?
Get it done right the first time dude. MIP BABY!
09-09-2014, 08:01 PM | #6 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: drive shaft ?
You can just buy the MIP Wraith set & bolt them on......but then have to deal with the pox Axial 3mm screw pins (with the 1.5mm hex, that strip easy) MIP C-Drive Spline Center CVD Wraith Or get the AX10 set, they still just bolt on, no mods, just get some of the Traxxas 4mm screw pins at the same time (that have the 2mm hex) https://www.rpphobby.com/ProductDeta...tCode=MIP08101 Traxxas Screw Pin 4x15mm Revo (6) plus its an extra $17 still in your pocket |
09-10-2014, 05:06 AM | #7 |
| Re: drive shaft ?
I'm running the AX-10 version of the MIP's on my Wraith. In addition to the Traxxas 4mm through-pins you will need to do minor clearancing to the spur gear cover to keep the output yoke from rubbing on it. The Wraith specific shafts have a smaller OD output, that uses the smaller 3mm through-pins, to clear the cover. |
09-10-2014, 09:29 AM | #8 |
Rock Stacker Join Date: May 2014 Location: casper
| Re: drive shaft ? |
09-10-2014, 01:25 PM | #9 |
| Re: drive shaft ?
I can take the gear cover off if I need to. 60$ for drive shafts is too expensive. |
09-10-2014, 05:04 PM | #10 |
| Re: drive shaft ? |
09-10-2014, 09:14 PM | #11 |
Rock Stacker Join Date: Aug 2014 Location: Somerset
| Re: drive shaft ?
MIP's here too on my wraith. Been running MIP an on a brushless stampede basher for years and never an issue.
09-10-2014, 10:41 PM | #12 |
Pebble Pounder Join Date: Apr 2014 Location: Trinidad
| Re: drive shaft ?
If you sticking with relatively tame motors and want to keep things cheap, a modified axial shaft could be for you.. it was discussed in the free or cheap mods thread on how to modify a stock shaft to increase its strength. You can get complete shafts with spare ends for under $20 on ebay.. I run a modified shaft and it seems much stronger than in stock form |
09-11-2014, 01:28 PM | #13 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
| Re: drive shaft ?
I actualy run modified Wild Boars with a Tekin Pro4. Seems to hold up just fine. Slipper properly adjusted so that it'll slip in terrible binds.
09-12-2014, 09:35 PM | #14 |
| Re: drive shaft ?
I ended up getting the junfacts. Maybe later I'll get the MIPS and out the junfacts on my honcho. I just hope they are long enough they say for the wraith but stock says up to145mm and the MIPS say up to 150mm and the junfacs say up to 142mm |
09-13-2014, 08:40 PM | #15 |
RCC Addict Join Date: Feb 2014 Location: Mt. Juliet, TN
| Re: drive shaft ?
MIPs all day long.
09-14-2014, 10:28 AM | #16 |
Newbie Join Date: Sep 2014 Location: Saratoga Springs
| Re: drive shaft ?
Mip here!
09-14-2014, 11:58 AM | #17 |
| Re: drive shaft ? If you got JunFac part# J90029 they will fit correctly.
09-14-2014, 08:40 PM | #18 |
| Re: drive shaft ?
OK good that's what they are. Thanks guys. It seems that MIP would be they way to go so one I'll get them and out the junfacs on my honcho. |
09-14-2014, 11:06 PM | #19 |
| Re: drive shaft ? |
09-15-2014, 08:59 PM | #20 |
| Re: drive shaft ?
That's what I had on there and they kept coming apart. I even tried putting a zip tie around the part where it makes the Y over the pin that goes through and they still kept coming apart. |
drive shaft ? - Similar Threads | ||||
best way to join a rwvo drive shaft to the output shaft on the axle | TRAV | Kyosho Crawlers | 12 | 01-29-2012 07:37 PM |
***MIP C-Drive Drive shaft for the AX10...GIVEAWAY*** | Rockpiledriver | RCP Crawlers | 153 | 07-01-2008 11:18 AM |
dRIVE SHAFT | Crazy Crawler | Newbie General | 5 | 10-12-2007 10:03 PM |
