09-28-2014, 10:03 AM | #1 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| No more chubs issues!!!
As we know chub issues can be a pita!!! I started with VP alum axles & the two screws on each side & did brushless upgrade(pro4 3300kv) the alum housing stripped so went to larger bolt. That lasted maybe two packs then same issue added beef tubes & worked really good but the lil 3mm stubby screw didn't get great threads because the beefy VP shafts longer bolt was hitting shaft so no go!!! Then I was reading SkaldidDog's wraith thread & seen him using epoxy type "stuff" to fix these issues & asked what all would work & went with JB Weld!!! Pics... Letting it set up for 24hrs... Colo r match was convienant!!! Complete & ready for testing next week! Still gonna get a DMG skid so diff want look abused like SkaldidDog's |
10-01-2014, 08:16 AM | #2 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: No more chubs issues!!!
You'll not have chub issues again. Crawl on. J |
10-01-2014, 08:08 PM | #3 |
The scale chubs may have fixed this issue, I'd red lokt them on anyways just know youl need heat to remove them
10-13-2014, 07:38 PM | #4 |
Rock Stacker Join Date: Mar 2011 Location: Dunlap
The scale chubs would habe been a great alternative i love mine just tighten down and dont worrie about it. Sent from my SM-T210R |
10-14-2014, 09:18 PM | #5 |
I want need to remove these unless they break! If they break I will cut & narrow the VP alum housing....... I have the scale knuckles on another rig which work really good on that rig the wraith pictured was constantly loosening so I JB welded to keep from happening ever again! |
No more chubs issues!!! - Similar Threads | ||||
Cannot get chubs off! | blakeguski | Axial Wraith | 2 | 06-27-2014 02:14 PM |
esc issues or elec issues | camogonewild | Newbie General | 5 | 03-11-2014 11:19 AM |
