10-15-2014, 11:09 AM | #1 |
Newbie Join Date: Feb 2014 Location: Milan
| Wraith shafts
Hi! Does anyone knows who makes beefy REAR shafts for the Wraith?? Thanks! |
10-15-2014, 11:35 AM | #2 |
Quarry Creeper Join Date: Aug 2013 Location: South Crawlolina
| Re: Wraith shafts
CREEPERBOB makes titanium ones. Pm him.
10-15-2014, 11:40 AM | #3 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Wraith shafts |
10-15-2014, 12:20 PM | #4 |
| Re: Wraith shafts
No ti is WAYYY stronger than steel. It is a lot lighter too. It has the highest strength to weight ratio of any metal.
10-15-2014, 01:55 PM | #5 |
| Re: Wraith shafts |
10-15-2014, 01:56 PM | #6 |
Pebble Pounder Join Date: Mar 2013 Location: Los Angeles
| Re: Wraith shafts I admit I'm not an expert but I believe most commercially available grades of titanium are in the same strength ballpark as steel. Some titanium alloys can be very much stronger than steel but those are pretty rare and it's pretty unlikely any RC parts would be made of them. The strength of titanium parts usually comes from the fact that it is so light weight. Parts can be made much beefier (thicker tube walls, etc.) while still maintaining a significant weight savings over a steel part. a solid hardened steel rod would be just as strong if not stronger than a solid titanium rod of the same dimensions but it would weigh a whole heck of a lot more! Go to a bike shop and look at bikes with titanium frames. They typically have much bigger tubes than a steel frame bike because you can use more metal making a stronger frame while still reducing weight.
10-15-2014, 03:15 PM | #7 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
| Re: Wraith shafts
^^^i agree with this. People for some reason get the idea that titanium is lighter then aluminum and stronger then steel. Not true. It is about the same weight as aluminum and the strength depends hugely on the kind of steel vs the kind of titanium. I work with titanium and stainless every day. Titanium is an amazing material but it is not always the best thing for the job. I have seen threads on guys wanting titanium tranny and diff gears. Unless you are looking to build a super light comp rig its just not a good idea. Hardened steel will hold up much better in that situation. As far as the shafts go, I would think the titanium might be as strong as hardened steel. Certainly stronger then stock shafts as they don't seem to be hardened much.
10-15-2014, 06:39 PM | #8 |
Quarry Creeper Join Date: Jun 2014 Location: San Mateo
| Re: Wraith shafts
With regards to rear shafts, I find they bend easily, I never break them they just get bent, Ti is much harder to bend than steel and retains it shape longer in my experience using Ti products for many years in DH MTB and Motocross applications. BUT it will snap/break in some situations where steel/Alu would just bend and could be bent back to get you out where Ti would leave you stuck. I look closely at the application before I choose, don't see many issues with Ti in the RC world (except the gear thing is correct always go with hardened steel or cromo.
10-15-2014, 06:45 PM | #9 |
| Re: Wraith shafts
Tinsel strength is what thats called. Aluminium is resilient and titanium doesn't possess that property. Titanium, as I stated before has the highest tinsel strength to weight ratio of any metal. CREEPERBOB uses very high quality titanium and you will never break or bend his shafts.
10-15-2014, 08:24 PM | #10 |
| Re: Wraith shafts http://www.rccrawler.com/forum/axles...le-shafts.html http://www.rccrawler.com/forum/axial...-shafts-2.html Here now that I got the chance to get to the computer again, I have the links. |
10-15-2014, 08:36 PM | #11 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: Wraith shafts
haha tinsel strength for the sake of accuracy I think you may actually referring to TENSILE strength, which is a materials resistance to stretching. Ultimate tensile strength - Wikipedia, the free encyclopedia And I would think it is actually the materials toughness that is more in question here, as it is unlikely you can stretch a Wraith axle to the point of failure. Toughness - Wikipedia, the free encyclopedia Locked-Up do a big fat SCX10 rear axle shaft, maybe with some gentle email/messaging persuasion they could be coaxed into doing Wraith/Yeti shafts too. I'm sure I also saw mention a while back of VP researching the development of CM 4130 shafts. |
10-15-2014, 09:01 PM | #12 | |
| Re: Wraith shafts Quote:
10-15-2014, 09:20 PM | #13 |
| Re: Wraith shafts
I didn't even figure it was your mistake, I just assumed it was another classic autocorrect failure that happened to be funny at the same time.
10-16-2014, 04:57 AM | #14 |
| Re: Wraith shafts |
Wraith shafts - Similar Threads | ||||
Wraith drive shafts | CHROMECRAWLER | Axial Wraith | 37 | 12-22-2019 06:54 AM |
wraith input shafts | Gen3_Teg_88 | General Crawlers | 2 | 08-16-2011 11:05 AM |
