10-22-2014, 05:17 AM | #1 |
Quarry Creeper Join Date: Jan 2007 Location: Italy
| WB8 HD WILDBOAR DRIVESHAFTS on Wraith
After having twisted both my Wraith driveshafts I'm looking for something more robust. Somebody suggested to use the eMaxx driveshafts, I have them, I couldn't try yet but I suspect they are not compatible with the transmission cover in the front. I think their diameter is too big and there is not enough space between the output shaft and the cover. Everytime I open Rccrawler I can see a banner about the Scx10 Falken with the WB8 HD WILDBOAR DRIVESHAFTS and they seem more robust than original Wraith ones. Are they completely compatible ? Can I buy AX31114 and use the male shaft with the Wraith female ? Do you thing it is a good idea ? Do I need other pieces ? Thanks Filippo |
10-22-2014, 12:46 PM | #2 |
Rock Stacker Join Date: Feb 2014 Location: peoria
| Re: WB8 HD WILDBOAR DRIVESHAFTS on Wraith
U could buy the wraith MIPS or junfacs. I have junfacs they bolted right up no problem. The scx10 shafts will be too short I think. U could buy a new set of wraith stock shafts u would need 2 sets I think though and use 4 female ends and cut the end off the male a put it in the 2 females so its a free floating spline in the 2 females. Junfac 90029 is the ones I have. I've beat the piss out of them with no problems. |
10-22-2014, 02:58 PM | #3 |
Newbie Join Date: Dec 2013 Location: Huntington
Since the male end of the stock driveshafts are hollow I found a piece of solid rod that is a tight fit and pressed it in there. Haven't had a problem yet on mine.
10-22-2014, 03:30 PM | #4 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
3pc hd's are just fine!!! they will interchange. im running a set on a 3100kv HH with 3s holdin up just fine!
10-24-2014, 12:44 AM | #5 |
| Re: WB8 HD WILDBOAR DRIVESHAFTS on Wraith |
10-24-2014, 02:54 AM | #6 |
RCC Addict Join Date: Aug 2007 Location: Seattle
3 piece means two female ends and one splined center. Scx shafts will fit a wraith. |
10-24-2014, 04:22 AM | #7 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
I run my regular Wildboars with a 4 pole brushless. I've mounted a female to both joints and have a floating male in between, with a 6mm allthread inserted. This is about the same design as the newer HD design. Have hold up to much abuse now. All parts needed comes with the kit, it's a free mod.
10-24-2014, 09:26 AM | #8 |
Pebble Pounder Join Date: May 2008 Location: tucson
I run both the old wild boar and the new updated 3pc hd and I like that the new hd come with 3 different length female and male pieces that allow for different wb lenghts
10-24-2014, 12:46 PM | #9 |
Newbie Join Date: Sep 2009 Location: Lakewood, CO
Looks like there will be Wildboar Drive shafts for the wraith soon. The new Spawn Wraith that has them, so they will most likely come out separately at some point. https://www.rpphobby.com/ProductDeta...ctCode=AX90045 |
10-25-2014, 07:30 AM | #10 |
Rock Stacker Join Date: Feb 2014 Location: Minneapolis
Here is the part Axial Racing - WB8-HD Driveshaft Looks like the same as the Yeti. I'm not sure if you would also need the bigger coupler? If that was the case, you might as well buy Junfac or MIP
10-25-2014, 07:37 AM | #11 |
the hd drive shafts will fit on the wraith trans and axles. im running them on both of my rigs with no issues
11-17-2014, 01:28 PM | #12 |
Quarry Creeper Join Date: Sep 2012 Location: Orange County, CA
I just unboxed my Wraith Spawn with the Wildboar HD driveshafts: http://youtu.be/aj2el_9tzsc Sent from my iPhone using Tapatalk |
11-18-2014, 02:31 AM | #13 |
My first idea was to upgrade only the male shaft from the inexpensive AX31114. I have now learnt that the improvement of WB8 HD over the WB8 is not limited to that part but probably the greater one is in the joint. Most pieces are now more robust, as the pin which is now 2mm instead of the previous 1.5mm. I suspect that pin will be the next weak point I'm going to discover. There is a special kit AX31133 for building two complete (?) WB8 HD driveshafts, it is definitely the right way to upgrade, but it is expensive. At this point I don't know any more if buying the WB8 HD or some other full metal driveshafts. Any advices ? Thanks Filippo |
11-18-2014, 04:09 AM | #14 | |
Rock Stacker Join Date: Feb 2014 Location: Michigan
i have installed the Emaxx drive shafts, all you have to do is. drill out the center of the yoke to match the pinion of the transmission and the axle. also you have to cut down the length of the drive shaft. there cheep and very strong. i have not seen a problem with this set up Quote:
11-19-2014, 01:30 AM | #15 | ||
| Re: WB8 HD WILDBOAR DRIVESHAFTS on Wraith Quote:
Anyway before spending more than 50$ for WB8 HD I can rethink about it, I have spare emaxx shafts | ||
11-19-2014, 02:22 AM | #16 |
Mine are getting awfuly sloppy. Havent taken them apart yet but there's considerable movement in the front shaft. Been happy with mip's in my other rig. Cost and weight suck. |
12-23-2014, 12:24 AM | #17 |
| Re: WB8 HD WILDBOAR DRIVESHAFTS on Wraith Here the spur is a 54T 0.8 mod. As you can see the clearance between the spur and the e-maxx shaft is not very much, and the spur is the smallest I can reasonably mount. I think the e-maxx shaft is a good and cheap choice for the rear but it is not the best solution in the front. Last edited by setecastronomy; 12-23-2014 at 12:27 AM. |
WB8 HD WILDBOAR DRIVESHAFTS on Wraith - Similar Threads | ||||
Wraith WB8 Driveshafts | Hardline | Axial AX-10 Scorpion | 21 | 10-19-2012 08:51 PM |
